Front Tow Hooks
The front toe hooks on my T-bar ends are gone. Would like to repace them.
Has any one used/bought one of these ? Not exactly a OEM replacement, looks like they would be better. More like the 914 design ? Tow Hook Assembly, 911 (1974-89) PEL-RDP201 |
Cary,
Have seen several aftermarket designs that try to improve on the stock unit. Have not used them personally but want to try one out. If you do, pls let us know how you like it. Joe |
Joe, did you look at the photo ? Doesn't it look like it lays horizontal ? That would be cool.
At $50, I think I'll give them a try. |
1 Attachment(s)
I think P201 needs to be welded onto pan in center. See Pic at PEL-RDP200. Are you looking for C-341-037-02 and C-341-038-02 ?
Cary,
Forgotten where I saw them last. Let me look around and see what I can find. Joe |
Cary,
Found these right away but have seen others. Except for the one from Pelican, they all bolted to the torsion bar attach point area and did the same as stock but a bit beefer. Will keep looking. http://www.pelicanparts.com/catalog/shopcart/911M/por_911M_chasis_main.htm http://www.theracersgroup.com/CCM.html http://www.bkauto.com/porsche/r9089.php |
Re: Front Toe Hooks
"toe hook" . . !?
Sheesh; kids are piercing everything these days.:rolleyes:
Couldn't resist :) It may help your searching if you go looking for a Tow-Hook |
Re: "toe hook" . . !?
Ron, I want a real tow hook.
On the OEM tie downs. I have 1/2 of one left. That weld on one looks good. It's just like the factory one on my 914. |
I'm a little slow.............................. I was a VP in my first life.
Opps...........toe......tow..........never even gave it a thought. |
Completely "Off the Hook"
If you guys were from Seattle I would understand . . .
after all, we do have Toe-Trucks here. http://forums.pelicanparts.com/uploads/1toetruck.jpg |
............ Ron |
Re: Completely "Off the Hook"
I don't want the cut a hole thru the FB race car type. :( TRE has one also, I couldn't quite figure it out from the picture. |
well, lets try this scan.. only took me 45min.. LOL
http://forums.pelicanparts.com/uploads/Welt9.jpg |
cary, if you would like a tow hook, i have one in the garage brand new like the one restoration design sells. i think it is a factory new porsche part. i will check the box tomorrow if you are interested. i will sell it cheap!
Thanks Ron. I hadn't seen that before.
Slammed, I'll have to get under there and ponder which one. |
I bought 2 used ones at Parts Heaven for $20, to replaced the ones on my SC.
As for the new Welmiester one's, I imagine a person with some decent tools (Cary) could make the same thing pretty inexpensively. |
| All times are GMT -8. The time now is 05:23 AM. |
