The front toe hooks on my T-bar ends are gone. Would like to repace them.
Has any one used/bought one of these ? Not exactly a OEM replacement, looks like they would be better. More like the 914 design ? Tow Hook Assembly, 911 (1974-89) PEL-RDP201
Cary 77 Carrera RS w/3.2 #59 73 914S 2.0 AG 73 914 1.7 Driver ( daily driver, under complete rustoration ) 74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor Last edited by cary; 12-28-2002 at 04:49 PM.. |
Senior Member
Cary,
Have seen several aftermarket designs that try to improve on the stock unit. Have not used them personally but want to try one out. If you do, pls let us know how you like it. Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Joe, did you look at the photo ? Doesn't it look like it lays horizontal ? That would be cool.
At $50, I think I'll give them a try.
Cary 77 Carrera RS w/3.2 #59 73 914S 2.0 AG 73 914 1.7 Driver ( daily driver, under complete rustoration ) 74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor |
Platinum Member
I think P201 needs to be welded onto pan in center. See Pic at PEL-RDP200. Are you looking for C-341-037-02 and C-341-038-02 ?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Senior Member
Cary,
Forgotten where I saw them last. Let me look around and see what I can find. Joe
Senior Member
Cary,
Found these right away but have seen others. Except for the one from Pelican, they all bolted to the torsion bar attach point area and did the same as stock but a bit beefer. Will keep looking. http://www.pelicanparts.com/catalog/shopcart/911M/por_911M_chasis_main.htm http://www.theracersgroup.com/CCM.html http://www.bkauto.com/porsche/r9089.php
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Information Junky
Sheesh; kids are piercing everything these days.
![]() Couldn't resist ![]() It may help your searching if you go looking for a Tow-Hook
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Ron, I want a real tow hook.
On the OEM tie downs. I have 1/2 of one left. That weld on one looks good. It's just like the factory one on my 914.
I'm a little slow.............................. I was a VP in my first life.
Opps...........toe......tow..........never even gave it a thought.
Information Junky
If you guys were from Seattle I would understand . . .
after all, we do have Toe-Trucks here.
............ Ron
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
Re: Completely "Off the Hook"
I'd like to look at them too.I don't want the cut a hole thru the FB race car type. TRE has one also, I couldn't quite figure it out from the picture.
well, lets try this scan.. only took me 45min.. LOL
cary, if you would like a tow hook, i have one in the garage brand new like the one restoration design sells. i think it is a factory new porsche part. i will check the box tomorrow if you are interested. i will sell it cheap!
Thanks Ron. I hadn't seen that before.
Slammed, I'll have to get under there and ponder which one.
I bought 2 used ones at Parts Heaven for $20, to replaced the ones on my SC.
As for the new Welmiester one's, I imagine a person with some decent tools (Cary) could make the same thing pretty inexpensively. |
