-   -   intermittant non-start issue is driving me nuts (http://forums.pelicanparts.com/porsche-911-technical-forum/922929-intermittant-non-start-issue-driving-me-nuts.html)
andyt11 07-24-2016 06:05 PM
The car is an 88 3.2 911, stock except for a Steve Wong chip and an exhaust.
For probably three driving seasons now I've had maybe twice a year where the car turns over but wont fire. Twice it happened after the car wash, the other times there was no water involved. I have never got to the bottom of it, because it fixes itself during the time I'm doing diagnostics.
This last time I didn't even get into diagnostics. The car drove out of town for an hour to a restaurant last night, but after the meal it would only turn over, it wouldn't fire and run. In the end we came home on a flat deck. The very next day today, I tried to start it. Same result, wouldn't fire up. So I pushed it around in the garage because it was in the way. When I was done, I turn the key just for fun, and the car started. It's infuriating, because now it behaves perfectly, and when I get into it with the multi meter, everything will check out just like in previous years.
This has happened five or six times over the last three years. Each time I find all the sensors etc check out as they should, coil is fine, DME relay is fine, idle valve is doing its thing, got spark, got fuel, etc etc... but at some point during diagnostics the problem vanishes. So of course everything checks out.
I do have a suspect main HT lead, I found it had failed/disintegrated last year and i re-crimped one end and put it back into service. It was late in the season. I've ordered new ones now as I suspect the lead is failing. Apart from that everything on the car checks out.
There is one other thing I noticed during the years, and that is when the car is in a non-starting condition, I can get it to fire really roughly for a few seconds if I unplug the AFM. But I think doing so floods the engine because you can really smell the fuel if you do that.
My plan right now it put the new HT leads on c/w with a dizzy cap and rotor. The ones that are on are not exactly in the best shape and it's time anyway. The car will run after that i'm sure, but then it runs right now. I'm unsure how I can know if I've fixed the problem.
So looking at this latest case, what can fail at random, and then be cured by being pushed around the garage for ten minutes?
88911coupe 07-24-2016 07:14 PM
In my case random no starts ended up being due to one of the RPM or reference sensors failing intermittently. I'd been under the impression they either worked or failed but in my case the resistance would be in spec and wildly out of spec depending on when I checked it. Ischmitz is the one who guided me through what to check and when. After replacing the buggy sensor it starts fine and consistently.
strikee 07-24-2016 08:56 PM
Im with 88911 on this one. I had the same thing. Would go to start the car and it would just turn over. Nothing. Walk away for five minutes. Shake the car side to side and bam, it would start.
I replaced both the reference sensors (with the BMW ones) and it has started first time every time since. One of the most rewarding DIY jobs I have done.
Don't be fooled into thinking its a five minute job. My reference sensors were pretty much stuck in the mounts. Lots of really good threads on how to do this.
Ed.
T77911S 07-25-2016 03:47 AM
replace the 2 sensors as above.
either replace the DME relay or pull it out and resolder the joint
ignition sw is another possibility although I think most of the tome with this it will not turn over
have a spare spark plug with you. when it will not start check for spark.
pulling the plug on the AFM probably puts the DME in a "default" mode. if it does, this mode will make it run richer. ( a lot of EFI cars will do this. I don't know for sure if the Porsche does or not). this mode is a "safe mode". since it does not know how much air is coming in it goes to a default setting of very rich.
kyngfish 07-25-2016 04:40 AM
Start problema
+1 to everything above. My bet is its the crankshaft position sensor/ref sensor. you mentioned that it happens after a visit to a restaurant? Does it happen more when the car is warm?
Look around on these forums. The speed and ref sensors are the same part just used differently. If you find the Bosch part number you can get them for 60 each instead of 150. Replacing rhem should be easy peasy as long as you don't have to regap the bracket and if they aren't stuck.
CCM911 07-25-2016 07:28 AM
In my case it was the ECU. Ingo Schmitz had me up and running in no time.
ivanuf 07-25-2016 07:52 AM
It also happened to me and it was the battery. It had the 12V but the cranking power was not enough to turn the engine. Once I would not start at all. I left it on the driveway plugged to the battery tender and it crank fine the next day, that Is how I figured out it was a weak battery.
andyt11 07-25-2016 09:51 AM
I thought they were either failed or not failed too. Perhaps I should reach out to Ischmitz and ask him what his thoughts are.
ivanuf 07-25-2016 02:24 PM
Nope, we sell batteries in our store. A simple volt meter will only give you voltage but you need to verify the CCA (cold cranking amperage) this values for my SC needs to be in the 600+ range to start the car. A reading of 12V with a CCA of 400 from a good battery will not move my starter or start my car.
DRACO A5OG 07-25-2016 02:32 PM
+1, if cold voltage is less than 12.5 volts, she most likely will not start and CCA is most important for our 911's
andyt11 07-25-2016 02:33 PM
By the sounds of things, as much as I hate to throw parts at a car, I should just spend a couple hundred bucks and swap out the two sensors and enjoy the rest of the summer. And a new DME relay for good measure.
This is such an infrequent condition (once or twice a year) but it's making it so I can't trust the car. Won't be taking it on another date in the near future that's for sure.
Although they only happen once or twice a year too ;)
DRACO A5OG 07-25-2016 02:42 PM
What is the voltage cold?
I have no issues, but I always put her on a tender just to keep the battery healthy and de-sulfating which kills batteries no matter the age.
andyt11 07-25-2016 07:45 PM
Right now I'm not sure. Its probably down from all the cranking on saturday. But as I said, it started and ran on Sunday, about 10 minutes after failing to start on Sunday.
I will put it on charge this week.
Joe Bob 07-25-2016 09:14 PM
If hot start, partially stuck solenoid or bad check valve in the fuel pump exit neck. Solenoid, whack it like a RH step kid, check valve replace. DME relay and sensors as suggested above. Those are the big four. Also, one that stumped me, worn fuse contacts from spinning to break ocean air corrosion.
mysocal911 07-25-2016 09:15 PM
Actually, most all vehicles should start in very cold weather when the voltage is as low as 9-10 volts.
Remember, there're climates other than what's found in SoCal, e.g. northern Europe, where the temp
is in the minus degrees C in the winter. Given that, how could any automotive manufacturer require that
a car's battery be at least 12.5 volts for adequate starting under all temps?
andyt11 07-26-2016 09:01 AM
Doesn't make any odds of the car is warm or cold, wet or dry. it's just as random and goes away just as random. Smells of fuel though. DME relay clicks twice. Car performs the same on a spare relay too.
When the car is refusing to start I get very definate tach bounce on cranking.
I read that the tach is given its signal from the reference sensors. If that's true, it would perhaps indicate that the sensors are fine and that I have no spark. I didn't have tools to check when it last broke down. And now the car runs if course.
Could the coil be failing intermittently? Would I get tach bounce if I didn't have a spark?
DRACO A5OG 07-26-2016 09:20 AM
Please check your voltage when cold or go to the auto parts store and have them check your battery and charging system, it should be free if a chain store. Make sure they check the CCA.
mysocal911 07-26-2016 09:49 AM
Correct.
Again correct. So you need to actually pull the coil wire from the distributor and check for a spark
(place wire 10mm from engine case).
Yes.
Yes.
andyt11 07-26-2016 10:48 AM
Next time it fails (probably a year from now) I'll check for a spark. Although I'm sure last year when I went through this we did check for a spark and it was present.
Last year it was kaput for a while and I was able to check the resistance on the position sensors and cht sensors. I'm sure we checked for spark, I'm sure we checked the DME relay socket too, and the relay.
andyt11 07-26-2016 10:50 AM
And Draco, I'll check voltage and charge battery tonight. It may be low, but that said it went from not running to running in about 5 minutes on Sunday.
And of course now it's running again there isn't much to diagnose.
DRACO A5OG 07-26-2016 10:59 AM
Oh no, please measure before you charge it up so we can see the current state of the battery.
When I was chasing down a no start low battery issue after swapping everything on the damn charging system, it turned out the positive side battery connector had a hairline fracture that was not allowing an adequate charging of my brand new battery from my brand newly re-built alternator.
When warmed up of course she started but if I let her sit she would either slow crank or not at all. Measured battery it was low, I was like WTF :eek: I was ready to yell at the FLAPS but went there and they tested my battery was Perfect, a little drained but it held its charge and CCA tested fine too.
I then decided I will replace both cables, neg side was ratty but when I removed the posi side, I noticed the fracture under neath, BINGO, replaced connector, not the cable, absolutely no more issues with charging system. I just hate for you to drive yourself nuts trying to locate the culprit.
andyt11 07-26-2016 06:05 PM
For what it's worth the battery has 12.3v right now and the car starts and runs. I'm going to top it up. Going through earth's over next few days and making sure they are all good.
McLaren-TAG 07-26-2016 06:33 PM
Intermittent stuff is difficult especially when they work 99% of the time. A faulty DME relay is a likely cause troubleshoot that, lots of details here with the two clicks being required but it's an easy check and you should already have a spare DME relay.
One thing I'll throw in and it's something that's a pretty straight forward DIY project. The DME itself, I have already had my car long enough to have replaced the CHT sensor, both speed reference sensors and the DME relay, a couple of months ago I took the car out for a drive Saturday night after having prepped it for an AX event on Sunday.
Sunday morning comes and no start, I did what I could at the time with very little time to troubleshoot, and it wasn't the DME relay. The car then didn't starts for a couple of days while I did my rounds of basic troubleshooting. Fuel checked, no spark so coil checked and everything was good.
I took out the DME, disassembled it and flowed every single pin on the connector and put it back... nothing was obvious but a very small cold solder may be extremely difficult to spot. I used to repair cell phones back in the late 80s and early 90s so I'm comfortable with electronics and a soldering iron. After the reflow everything worked flawlessly. These 3.2s are 30 years old plus, things happen. Don't be afraid to try the things that others have suggested here, often times they are golden. Its a good winter project even if it's not the case, it's always a prudent project to take on.
DRACO A5OG 07-26-2016 07:51 PM
Well, per Bentley, 12.3 equals to approximately 62.5% of full capacity. I do not know about anyone else, but that is not acceptable.
What is the voltage when car is on at 1800-2000 RPMs, let's make sure alternator is charging her too.
andyt11 07-26-2016 08:34 PM
Thank-you for all the help so far everyone.
I've been through all the grounds tonight and removed and polished and reinstalled each and every one.
I have the battery off because one of the grounds was located behind the battery. While it's out I'll get it load tested. Just to make sure it's not at all questionable.
After that I'll check voltage at two grand and report back.
After that I'm thinking I'm going to reflow the DME board. I don't suspect the relay. I've got two and swapping them has never resulted in the car changing from non start to start, or vice versa.
Can you guys think of a way the coil could be the culprit or perhaps the ignition switch? I'm just thinking a few steps down the road here.i can't understand why it went from non starting to starting, just because I pushed it around the garage on Sunday
andyt11 07-27-2016 05:31 PM
Battery was fully charged last night. Currently sitting in garage with 12.6v.
Just leaving part source. He load tested it, says it's fine.
DRACO A5OG 07-27-2016 05:33 PM
Outstanding, now to the next suspect.
Alternator, please test at 1800-2000 RPMs and post voltage.
Side note, take a close look at the battery terminal connectors, above and below for any hairline fractures. Use a bright light and or magnifying glass. A fracture will cause havoc.
andyt11 07-27-2016 06:22 PM
Tested the battery at a second place on way home. They put it on two different machines and proclaimed a clean bill of health.
When I got home I hooked up the multimeter and fired up the car. Went up to 13.3 or there abouts at idle, but the engine died after about 3 seconds, never to restart. I will start checking coil etc tomorrow. Hopefully it stays broken.
andyt11 07-27-2016 06:28 PM
Just before I quit, I had my wife crank the car over while I watched for a spark. I don't have a spark.
DRACO A5OG 07-27-2016 07:05 PM
Oh man that sucks.
The OHMs on ref and speeds sensors check out too?
DanielDudley 07-27-2016 07:24 PM
These are exactly the symptoms I am having. Replaced the reference sensors and DME relay, and no change. I get tach bounce, and a big bounce when it decides to fire from dead when cranking. The old sensors appear fine, and are not really very old, old DME relay is fine.
Sure seems like a bad solder connection.
andyt11 07-27-2016 08:01 PM
I've got tach bounce too. Sensors checked out last year when I went through all this. Will check again but I'm sure they are going to be fine.
Could the coil or ignition switch be the culprit? If not, I think I'm going to have to open up the DME and attack it with a soldering iron. Seems like a big step to take.
rick-l 07-27-2016 09:00 PM
If you are nervous about that you could private message Ingo and see what he says about it.
I think he must be out of town or he would have picked up on this thread.
Pelican Parts Technical BBS - View Profile: ischmitz
CCM911 07-28-2016 06:56 AM
When mine went it was totally intermittent. Send the brain to Ingo for a test. Not expensive at all.
I went through the same thing as you. Changing the DME realys seemed to help, but was probably just coincidence.
Good luck!!
ischmitz 07-28-2016 08:28 AM
Just saw this and send Andy a message responding to his email. Now that there seems to be (some) spark I would introduce fuel just to see if that makes a difference. It somewhat points away from the FW sensors.
It could be an intermittent DME relay (fuel pump runs only sporadically), a bad fuel pump (weak output, happened to me), or something in the DME (spark output). Once you stray a healthy dose of brake cleaner or similar into the intake and then crank it'll tell you.
Cheers,
Ingo
mysocal911 07-28-2016 09:39 AM
Most likely your problem is here:
http://forums.pelicanparts.com/uploa...1469723616.jpg
That's the one of the three pins of the ignition driver transistor. Just re-solder each of
the three pins. You'll find the driver on the aluminum heat sink on the right side of the
ECM when viewed from the front. That's the most common problem with the ECM.
DanielDudley 07-30-2016 03:51 PM
I went over the DME on my car, but it may in fact be a bad connection on one of the primary wires going to the positive terminal on the battery.
Definitely check the terminals on your battery. PO had messed with mine.
andyt11 07-31-2016 12:40 PM
Just an update. Ingo was kind enough to exchange some emails with me and felt there was a real chance my position sensors were failing or that the actual DME has a fault. I also checked in with Steve Wong since it's one of his chips in there. He had similar thoughts re the chance of a DME fault.
The insulation on the position sensors has failed completely from heat, leaving the metal shielding exposed to moisture. New ones have been ordered along with a new DME relay just for good measure. And the DME itself has gone to Steve for testing / repair. Ingo also offers this service and I'm sure either guy can take care of it. I only chose Steve because I've dealt with him before.
So thanks to all for the help so far. Especially Ingo for his detailed emails. I do appreciate it.
Will update when the DME comes back and the new sensors are installed. I'm hoping that's the end of it.
DanielDudley 07-31-2016 03:19 PM
The insulation on the position sensors has failed completely from heat, .
Well there you go. Lots of threads on replacing these, but I found that I had to use a little WD40 and some vice grips to get out the worst offender. I also wound up putting a block of wood against the transaxle and using a pry bar against the vice grip to nudge it out. Removing the duct hose from the heat exchanger will give you access.
mysocal911 07-31-2016 03:48 PM
Since you have benefited from the Pelican Parts Forum and its info, you could have utilized Pelican Parts,
since it provides a rebuilding service too. Hopefully, you at least ordered your sensors from Pelican Parts, right?
