Born to Lose, Live to Win
ramonesfreak's Avatar
911SC 915 shifter removal question
Im in the process of installing all new bushings.
Going through all my socket sizes, cant find anything that fits the bolts that hold the shifter to the tunnel
There is not alot of room around the bolts to fit a socket. Is a special tool needed?
Also, I see 3 larger bolts (2 in front, 1 in rear) and then 2 small bolts (in the rear)
Am i just removing the 3 larger bolts or do all 5 bolts need to come out?
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 07-31-2016, 01:45 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Did you remove the seat/s, heater console and peel back the carpet? It will really help.
Those should be ALLEN ( Inserted Hex ( 6 sided ), three larger two smaller for the horizontal portion of the shifter/input.
Loosen the smaller ones then remove the 3 larger ones, lift the base up and then remove the two smaller ones as you hold the bracket for the bushing.
'85 Carrera Targa
PCA/POC
Old 07-31-2016, 01:50 PM
Yea removed console and pulled carpet up to expose base of shifter
I got a 1/2 inch socket to fit on the big bolts. They are not ALLEN. Car is a 1983, not sure if that matters.
I think I figured it out. Thanks
1983 911sc
Old 07-31-2016, 02:02 PM
DRACO A5OG's Avatar
Oh good. long as it works. Break a leg!
'85 Carrera Targa
PCA/POC
Old 07-31-2016, 02:16 PM
