74 911 fuel gauge moves under throttle
So, my car recently had the fuel pump changed. What I noticed now is that the fuel level needle moves up when I accelerate. If doesn't make a big jump, just a little bit, but it's very noticeable. Like it will go from reading a bit less than a quarter full to a bit more than a quarter. Then if I take the foot off the gas it goes back down. Is that normal?
"Fraud is everywhere in this hobby. Believe nothing, believe nobody, expect disappointment." |
Member 911 Anonymous
Did you do the swap or a shop?
You should see some movement but that does seem allot. Try a hill as a controlled test, accelerate slowly up, brake on the down side and observe gauge if safe to do so while in motion. When my reserve light comes on, on hills, it will go off and on depending on position of the car on the hill but my gauge barely moves.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 08-06-2016 at 08:52 AM.. |
If you look at the fuel sender you will see that the float sits in a relatively long tube and this holds fuel around the float.
There is a relatively small hole that allows the fuel to drain out of the tube and if the float tube is full it can take quite a time to drain. This effectively helps to damp the gauge so it should be quite slow to move. Have you checked the tank breather? If this has become kinked you may have a varying vacuum level in the tank and this can cause funny tricks. |
Thanks, I'll do the hill test and bear in mind about the tank breather. A very good shop did the swap...
Sent from my ONEPLUS A3000 using Tapatalk
If your '74 still has it's original mounting place (rear) for the fuel pump it's unrelated to the gauge movement. Even if it's moved to the front it should not affect the gauge.
In my '74 the gauge will swing as much as 1/4 of a tank under hard acceleration, braking and cornering (really noticeable on track days) - depending on the overall level in the tank. Like the oil level gauge, best reading is sitting still, on level ground with engine idling. Second best is driving smoothly on level ground. Don't worry about it.
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
