-   -   Injector test question + fan ? (http://forums.pelicanparts.com/porsche-911-technical-forum/923793-injector-test-question-fan.html)
Steve F 08-01-2016 07:58 AM
Question #1
Did a bunch of reading and have not seen this addressed yet. I have the steel fuel lines to the injectors (1981 SC) , I would love to spray pattern test them as I have the rest of the system in soon, but has anyone done this with the steel lines without bending them?
Question #2
Just was wondering what attaches to the skinny "L" bracket on the driver side electric blower fan, can't see anything I'm missing?
Thanks SmileWavy
DRACO A5OG 08-01-2016 08:02 AM
Why not just remove them and observe each one like the refurb shops do?
Steve F 08-01-2016 08:12 AM
Thanks,
They are removed but wanted to use the FD to check flow and pattern in jars, without bending the fuel lines.
gazzerr 08-01-2016 08:13 AM
You can remove them, stick them into baby bottles and lift the sensor plate to watch the spray pattern and verify they don't leak. The lines will move a fair amount without you having to worry about bending them. You would have to really abuse them to bend them.
I disconnected the lines, pulled the injectors and reconnected the injectors to the lines before putting them in the bottles.
DRACO A5OG 08-01-2016 08:17 AM
Post some pics OP, love to see this, maybe a video?
Steve F 08-01-2016 08:18 AM
Excellent.....Thanks very much!
gazzerr 08-01-2016 11:52 AM
Sure good luck! The skinny L bracket good question. Probably something on the 70's or earlier models I guess.
Steve F 08-01-2016 12:04 PM
Good, then it is GONE! Total PITA to work around it:)
Cheers,Steve
gazzerr 08-01-2016 01:19 PM
On mine it's joined to the bigger bit that mounts the heater fan if we are in fact talking about the same thing. Nothing on the skinny bit though. Lots of guys delete that heater fan.
