Wer bremst verliert
JohnJL's Avatar
Resistor on cutoff switch
I am transferring the cutoff-switch wiring from one car to another. It was on the 71 but since restoration the Pegasus 6-terminal cutoff switch has been sitting in a box.
I went to reuse that switch in Gretchen, and the resistor connection broke. It is a pair of solid wires into a ceramic resistor. I need to replace the resistor, the lead is broken off at the base.
I have another spare pegasus switch to scavenge the resistor but I want to keep that a complete set.
I need some other things off Digi-key so no worries, except the labelling is inconsistent between resistors. The old one is labelled 3R3 10%. The new one is labelled 3.3k 11W.
To my knowledge, it is 3.3 OHM and 10-11W. Digikey has familiar-looking ones labelled 3.3 Ohm 11w for reasonable prices ($1.) They do have 3.3K OHM 10w but they look very different and are quite different price and unavailable anyway.
I would greatly apreciate if soneone could confirm the stats needed on a cutoff switch resistor?
Thanks!
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 08-07-2016, 07:23 PM
Wer bremst verliert
JohnJL's Avatar
This one?
http://www.digikey.ca/scripts/DkSearch/dksus.dll?Detail&itemSeq=203937479&uq=636062014440233466&DPU=submit
Old 08-07-2016, 07:25 PM
Platinum Member
dad911's Avatar
3.3 ohm, 11 watt
https://www.pegasusautoracing.com/productdetails.asp?RecID=1468
If you have any radio shacks left near you, (3)10 Ohm 10w resisters in parallel will work.
Old 08-07-2016, 10:31 PM
