POVI's Avatar
Help .. 7 + 9 x 16" fuch on early rs body ?
Hello all ,
Im nearing completion on my 1970 911 rs clone with 3.6 liter motor , and my question on Fuch wheels is ...
Will 7 + 9 " x 16 " Fuch wheels off a 911 turbo fit my rs flared body , or will I have to go the spacer route ?
Thanks to all in advance !
ALSO .. im looking to purchase a set of 7 + 9 x 16 "
fuchs .. if you have some drop me a line with price and condition ect ..
thanks
Joe
Old 12-27-2002, 07:15 AM
They should fit, but it is going to depend on the tire size and height. Rolling your fender lips is a good idea. The cool Fuchs for the front are not the 16x7's but the 16x8 944 Turbo offset rims.
I run 16x9 in back with 265/45's and 16x8 (944 turbo) in front with 245/45. All my lips are rolled. You also need to look at the rear clearance for your oil cooler lines if you are running an external thermostat and front oil cooler.
Old 12-27-2002, 09:48 AM
Bill Verburg's Avatar
There should be no problem at all in the back where 245/45x16 is by far the best choice for 9x16 w/ no mods required. If you go much wider the oil lines will need relocation, the trailing arm bolts are the next interference point.
The front is more problamatic, especially left front. Many including myself, have had little trouble w/ 225/50x16 on 944 8s, others have had insurmountable difficulties. I have yet to determine whether the chassis or suspension is the issue(perhaps a combination or just bad karma).
+23-25mm o/s 8s will fit fine on my car but I have totally shaved the lips off.
+23mm o/s 7s w/ 205/55x16 fit w/o any lip mods
Bill Verburg
Old 12-30-2002, 05:50 PM
wheels 4 sale
Hey Joe
I believe that Mike Z has a set of 8's & 9's for sale. I saw them a few weeks ago He has kumons that go with them I think!
Old 12-30-2002, 08:11 PM
Calspeed's Avatar
Hello,
I spoke with "Harvey" (?) of Weidman Wheels here in NorCal and he cautioned me against mounting 225's on my 16x7's if they were to go on the front of my '85 Carrera. He recomended me using 205's.
I was under the understanding that 225's would be more then fine on a 7' wheel. Was I wrong? I will be sending him a Tire Rack order shortly and I want to make sure I dont get the wrong size tires.
Calspeed
2008 Porsche 911 Turbo - One of the Baddest 997 Turbo in the SF Bay Area
1985 Carrera Cabriolet - The 2nd Baddest 911 Cab in the SF Bay Area. (sold in 2006)
Old 12-30-2002, 10:16 PM
skinnerd's Avatar
225's on 7" rims are perfectly fine.... I've done it a number of times as well as seeing tons of other people do it to.
Why were you cautioned not to mount 225's on 7" rims?
Clearance issues or too wide a tire for that wheel?
It should work.... Good luck.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 12-30-2002, 11:13 PM
225's up front on 7" can cause some problems with certain cars. There is definetly a bulge in the sidewall on these tires compared to the 205's. That is were you'll get rubbing on the the shock towers or inner fender wall possibly. Not for all, and that point has been spoken on. I ran 225's on 6's for track tires and they rubbed up front. I think the best way to run a 225 up front comfortable is with the 8x16 951 rim.
Old 12-31-2002, 05:25 AM
RETIRED
Joe Bob's Avatar
Re: wheels 4 sale
Originally posted by Speedy1
Hey Joe
Nope...7s and 8s....225/45 and 245/45 Kumhos, with caps....$1200.00
Turbo/SC/Carrera offset.
Old 12-31-2002, 08:25 AM
