Which Fuel Lines to Replace?
The fire-side chat makes me think that renewing fuel lines is a fine idea, a good piece of preventive maintenance.
Which lines would be reasonable replacement candidates? '78 SC.
Kristian
Old 12-30-2002, 05:15 PM
Jbabic's Avatar
I would make a bend check on all your fuel hoses....from the front fuel pump to the fuel distributer, WUR and back again. if you remove segments and the are cracked or cracked when you bend them, they should be replaced....I did mine and it isn't a hard job, if you take your time...I taped the new one to the old one, when pulling the old fuel line out. this was the line from the fuel pump through the transom to the rear of the car.
Old 12-30-2002, 05:30 PM
