Window crank knob split.
Does anyone have a solution for the spilt window crank knob problem? The driver's side crank knob was split when I bought my car, I bought a replacement (Performance Products, as I recall), and within a couple of years it split again. I am not hard on the window crank. It appears that the knob has a seam that is inclined to splitting. Are the OEM knobs any good?
Thanks, Doug 75 911S |
I replaced mine with aluminum....turned on a lathe.
I just copied the originals ...with the intention of getting them black anodised later. The nice thing...they are tapped..so I use machind screws to hold them on (makes them removeable). Bob |
Even without being hard on the crank, the originals are weak. It never hurts to be sure the winding mechanism is well lubed...
| All times are GMT -8. The time now is 01:59 PM. |
