1974 911 probs
Hi
I gave my husband a lesson driving stick in our new 1974 911 - now the the car vibrates and the tachometer is bouncing. We've done a search for other threads but this is a specific scenario.
- The car was pulling smooth and strong this morning through all the gears before the lesson.
- the lesson mostly practicing clutch control only.
- the was plenty of stalling and starting
- it doesn't accelerate in the same way now and topping out at 50mph.
- there is vibration in 3rd, 4th and 5th.
We just bought the car two days ago.
any ideas folks would be amazing.
we'll try them tomorrow.
many thanks!
Emily and Tony
Old 11-28-2019, 06:06 PM
Hi Emily,
Welcome to the air cooled family!
Only had the car two days...well a little history on the recent maintenance would be a good starting place. If no history I would do a complete tuneup to get a base line and then re-evaluate the symptoms.
Wife is calling gotta go for now,
Rahl
Old 11-28-2019, 06:39 PM
Thanks! Very excited to be part of the fam! Cheers Rahl
Hopefully taking it for a tune up on Monday is the fix.
The car was sitting for many years until the seller took it to a pro. It got a full quality rebuild this year and a long list of fresh parts.
Its currently running on brake-in oil, a full tank of gas and a can of 44K fuel system cleaner. Still in the break in phase.
Old 11-28-2019, 08:45 PM
Mark Salvetti's Avatar
Welcome Emily! Post some photos of the car when you get a chance.
I'm wondering if you are seeing some fuel system issues. Do you have the invoice for the work that was done? I'm curious whether the fuel tank was replaced, or at least thoroughly cleaned after sitting for a long time.
Mark
1979 911SC Targa
Old 11-28-2019, 10:03 PM
RETIRED
Joe Bob's Avatar
Post your location,,,,,we do house calls......
2012 ML350 3.0 Turbo Diesel
Old 11-29-2019, 12:33 AM
Armin
First off, congratulations. Can you provide more specifics as to what was done with the last rebuild?
Also send us some pics, this community has hungry eyes and we get really excited.
Old 11-29-2019, 01:38 AM
If the tach is bouncing around and the engine isn’t doing the same thing, then you should suspect an electrical issue.
Might want to check the health of your points and other ignition components as well as the electrical connector in the rear of the engine compartment, grounds and starter wiring- lots of power is fed through the starter to the back of the car and engine along with the alternator power.
Welcome and best of luck.
Rutager West
Old 11-29-2019, 02:10 AM
Harpo's Avatar
Congratulations, 74's are awesome, please post photos and tell us about the car
Old 11-29-2019, 05:10 AM
Hi Emily,
You can do the tune-up and regular maintenance yourself. 1974 911s are very easy to work on and having a 45 year old car you will need to be able to analyse and repair issues when you are left on the side of the road. You will be amazed at what you will be able to learn and repair on your 74 911. I like to read the tech section to see what issues others have had use that info for myself many times.
Rahl
Old 11-29-2019, 08:24 AM
Warren Hall Student
Bobboloo's Avatar
As previously stated by rwest, an electrical issue is most likely, more specifically possibly the points. If the distributor shaft is not properly lubricated the points will close up on you. Conversely if the set screw was not properly secured then the points can open on you. Since the tach runs off the pulse from the points it's a good place to start.
Old 11-29-2019, 09:08 AM
Hi Folks
Totally agree Rahl, we never owned a car and figured why not but an old Porsche and learn to fix and maintain it than something full of computer chips.
The 74 is a barn find that had been sitting for over 30 years before it went through a full internal rebuild. The car smells of hay and cigarettes, the paint is chipped and scratched but it adds to the charm. The engine work is beautiful.
To add to the fun we are planning to drive it back across the country from CA to NY.
(We checked - the heater works!)
Old 11-29-2019, 09:09 AM
Thanks everyone. We will have a look today - We think turning the ignition over a few too many times might mean an electrical problem - Can that drain the battery?
Here's a short list of the work done on the car this year. We didn't list every gasket and bolt...pics coming
Oil and filter change
Drain Crankcase and oil tank
New fuel tank
Fuel level sender
Fuel filter replaced
Fuel pump replaced
Fuel accumulator replaced
Clean out pressure and return lines through body and rear.
Machine shop - block, oil bypass, stud case savers, deck cylinder spigots, deck all case half fastener*flats, clearence for 964 oil pump, check align bore.
Machine shop - valve job 911
Replace valve guides, cut seats, test springs, set spring height, flycut heads.
Crankshaft cross drill and micro polish
Camshafts standard regrind
Recondition rocker arms
New 911S pistons and Cyl
Timing Chain tensioner upgrade
New Alternator
New Spark plugs
Sway bar bushings
Accelerator linkage bushings
Brakes rebuilt front and rear
Brake hoses replaced Front strut insets replace
Rear shock absorbers replace
Engine pad replaced
New Clutch kit
New Main bearing set
New Rod bearings set
Alt belt, gaskets, and hosesFuel accumulator replaced
Shift linkage bushings
Mainshaft seal replace
New Battery
4 wheel Alignment
Old 11-29-2019, 09:19 AM
Bitter chocolate 1974 911 with 62k original miles. Sitting in a barn, smooth out the teething problems and get it ship shape for a 3600mile roadtrip...hopefully photos appear below...
Old 11-29-2019, 09:42 AM
I would rather be driving
jpnovak's Avatar
Sounds like points to me. vibrations are from the mis-fire. tach bounching is due to the incomplete openin/closing of the points.
The points are located inside the distributor cap. This is the spring loaded switch that opens and closes as the hexagonal center shaft cam of the distributor rotates past.
There are several articles about adjusting points on a 911. I would start there. It only takes a screwdriver and feeler gauge and about 10 minutes of time.
Often the earlier cars with points will have them converted to more modern trigger mechanisms. For example, Pertronix or a Crane Optical. These are both a one-time setup during first installation.
Old 11-29-2019, 09:53 AM
We are starting an instagram account for the road trip across the south...
Follow @beans.911
Pray for us.
Old 11-29-2019, 12:45 PM
southern route, good idea
Old 11-29-2019, 12:50 PM
Send a message via AIM to fintstone
This was my first thought as well. Either this or a loose wire/connection in the ignition circuit (between distributor, coil). When you check for loose/burned points, take a good look at the rotor and inside of cap.
Nice car. Welcome to Pelican/911 ownership.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 11-29-2019, 12:57 PM
Functionista
manbridge 74's Avatar
Nice car! I’ve had three of these 74s and my current one has been a lot of fun.
I certainly wouldn’t entertain a long trip with rough running/on five cylinders but perhaps you have the issue resolved? Might be a good idea to check your fuel pressures and CO (fuel mixture) along with the other good advice above. Reason being, with all the reviving of fuel system the fuel distributor could have some rusting due to ferrous parts. The base fuel pressure might be a little low as the pressure regulating valve can be “weak” after 45 years. It is adjustable to some degree...
I will be watching your trip and can offer service/parts (and certainly prayers) from Colorado Springs if you come through this way.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 11-29-2019, 04:16 PM
Functionista
Good on you for removing engine w/o trans though it sounds like a real pain and I’ve never done it like that...
Nice fog lights that look original to the car I think. Only in 74 were they chrome (on mid-years).
Jeff
74 911, #3
Old 11-29-2019, 04:31 PM
Well, this car is a sassy little mare - we took it out for a run and over an hour it slowly came back to form - tach bounce was easing out and the shifts up through the gears were smoothing - though the speed and pull in 5th that was there before was a little less strong.
Then the drama - in the evening as we were going up a hill it died. The alternator light came on. Tach was bouncing. Several starts caused backfires through the exhaust. We got it to a car park thankfully and towed it back.
Monday we are towing to the mechanics for help.
Might take a look at some Crane products - we need reliable running not racing from this Pcar.
Wish us luck.
Old 11-30-2019, 09:29 AM
