keitho64's Avatar
Wide 15" Tire choices - Drag Radials?
My 69 has Dunlop D40 245/45-15 tires on the rear. They are about 30 years old, hard as a rock, cracks and will not stick to the road.
I tried a set of Hankook Ventus 265/50-15 but they were terrible. While the car cornered OK, it was terrible at anything over 50MPH. The tread squirm was unreal. I thought about having them shaved to eliminate the block tread. The salesman at Discount Tire recommended a Nitto NT555 Drag Radial 275/50-15. I was VERY leary but he was confident they would be way better than the worn Dunlops or the Hankooks. He offered me a deal where I only had to pay the difference in the price of the tire. I figured I had nothing to loose since the Hankooks were so bad.
I may be one of the few people with Drag Radials on an old 911 but I have to say they work fantastic. I was expecting a lot of sidewall flex but that is not the case. The car corners every bit as good, and better than ever before.
If you are in the market for a wide 15" tire I would recommend checking out Nitto NT555 Drag Radials. I am very happy with them!
Keitho64
05 GTO
00 911 C2
64 Corvair
Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles
Old 08-27-2016, 07:31 PM
Elombard's Avatar
I have wondered about those. They look like R comps. How wide are your rims. 9"?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 08-27-2016, 08:25 PM
Elombard's Avatar
There is several other 245/45 options did you consider those? The 275s look a little tall.
Old 08-27-2016, 08:27 PM
Crotchety Old Bastard
RarlyL8's Avatar
I run drag radials as well, however the side wall height of 315/35-17 is much shorter which makes a lot of difference.
Old 08-28-2016, 04:38 AM
Retired, finally
SiberianDVM's Avatar
What are y'all running in the front?
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 08-28-2016, 08:04 AM
keitho64's Avatar
I did not want to go shorter than 245/50 and did want a bit taller. With the gearing I have 4,000 was about 78 in 5th. The taller 275 drops that down some. I know they are a bit tall, but they serve my purpose.
These tires are R compound.
I am running Falken 225/50 on the front.
I believe my rims are all 15x8 but the rear's may be 9. I didn't check.
If I decide to go with a 17" Style Fuchs I would have better choices however personally I like the period look of the 15's on my car.
Keitho64
05 GTO
00 911 C2
64 Corvair
Old 08-28-2016, 08:20 AM
keitho64's Avatar
I have had time to put some more miles on the car. I am very happy with the results. The car holds the corners better than ever. I never would have expected them to perform this well.
If any of you are looking for a nice wide 15" tire make sure to add Nitto NT555R drag radials to your short list. I am sold on them!
Old 09-04-2016, 07:57 AM
