-   -   B&B headers distance between L/R side (http://forums.pelicanparts.com/porsche-911-technical-forum/927490-b-b-headers-distance-between-l-r-side.html)
faverymi 08-31-2016 05:54 PM
Can anyone with B&B headers measure the distance between L and R exhaust flanges where they meet the muffler? Please.
Trying to brainstorm with a muffler for my 3.8 (headers coming)
Thanks a lot. F.
sugarwood 08-31-2016 06:57 PM
I can do this, but be more specific what you want measured.
A photo helps.
faverymi 08-31-2016 07:53 PM
Simple line connecting the the L and R bottom bolts at the exhaust flange where headers meet the muffler
http://forums.pelicanparts.com/uploa...1472698350.jpg
faverymi 08-31-2016 08:01 PM
Trying to actually build something like this.
Muffler is out of a 997.2
http://forums.pelicanparts.com/uploa...1472698860.jpg
$ Short 09-01-2016 06:25 AM
No measurements , but I did use that muffler w 993HE's it was loud.
Good luck
faverymi 09-01-2016 09:07 AM
Current set up. Very liveable .
B&B headers will need different muffler.
http://forums.pelicanparts.com/uploa...1472746045.jpg
Quicksilver 09-01-2016 09:13 AM
That muffler is perfect for B&Bs. You just need to rearrange the tubing. You will want the muffler more vertical with the inlets at the top and the outlets at the bottom.
faverymi 09-01-2016 10:49 AM
I should say I want a different muffler : )
Cook&Dunning 09-01-2016 04:19 PM
I get 34.75" from center of lower flange bolt - left to right on my B&B headers. Please keep us posted on your project, I am very interested. I currently have a magnaflow (which sounds awesome) but like you I also found an Eberspacher off of an S. Good news is inlet pipes and flanges are same size, bad news as you know is same measurement on 997 is ~ 37.5", so you might need to fab. I am planning on rotating the muffler around, hoping to fabricate an RS style muffler with straight pipes exiting from round areas in center of muffler, that can be capped off. Then a single side out in stock position. Loud when I want it, capped off for the neighbors
http://forums.pelicanparts.com/uploa...1472771373.jpg
sugarwood 09-01-2016 04:22 PM
The distance from bolt to bolt is about 36.75"
This was not an exact measurement but pretty close.
faverymi 09-03-2016 03:24 AM
Thank you for the data.
This will be a winter project. Right now I'm gathering parts.
I will be building 2 separate mufflers for the headers. Loud and louder.;)
If I can get my hands on a cheap gt3 can I'll do that too.
More to come
