B&B headers distance between L/R side
Can anyone with B&B headers measure the distance between L and R exhaust flanges where they meet the muffler? Please.
Trying to brainstorm with a muffler for my 3.8 (headers coming) Thanks a lot. F.
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
I can do this, but be more specific what you want measured.
A photo helps.
1986 Bosch Icon Wipers coupe. |
Simple line connecting the the L and R bottom bolts at the exhaust flange where headers meet the muffler
Trying to actually build something like this.
Muffler is out of a 997.2
No measurements , but I did use that muffler w 993HE's it was loud.
Good luck
2010 Carrera S GONE 2022 Cayman T 2007 GT3 1988 Carrera |
Current set up. Very liveable .
B&B headers will need different muffler.
Diss Member
That muffler is perfect for B&Bs. You just need to rearrange the tubing. You will want the muffler more vertical with the inlets at the top and the outlets at the bottom.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Occasional User
I get 34.75" from center of lower flange bolt - left to right on my B&B headers. Please keep us posted on your project, I am very interested. I currently have a magnaflow (which sounds awesome) but like you I also found an Eberspacher off of an S. Good news is inlet pipes and flanges are same size, bad news as you know is same measurement on 997 is ~ 37.5", so you might need to fab. I am planning on rotating the muffler around, hoping to fabricate an RS style muffler with straight pipes exiting from round areas in center of muffler, that can be capped off. Then a single side out in stock position. Loud when I want it, capped off for the neighbors
Vince 2015 Boxster S, Black & Black 1989 Carrera Silver Coupe, Silk Grey - sold 2009 Cayman S White, Full Cocoa - sold 1972 911E Silver Coupe, Pepita & Black - sold Last edited by Cook&Dunning; 09-01-2016 at 04:28 PM.. |
The distance from bolt to bolt is about 36.75"
This was not an exact measurement but pretty close.
Thank you for the data.
This will be a winter project. Right now I'm gathering parts. I will be building 2 separate mufflers for the headers. Loud and louder. ![]() If I can get my hands on a cheap gt3 can I'll do that too. More to come
