-   -   New alternator bearings failed only one year after installation (http://forums.pelicanparts.com/porsche-911-technical-forum/927739-new-alternator-bearings-failed-only-one-year-after-installation.html)
martidj 09-03-2016 08:18 AM
The other day I backed my 911SC out of the garage parked it and turned off the engine. After a couple hours I started my 911SC to return it to the garage when I hear grinding noise coming from the cooling fan. Immediately I turned off the engine to investigate, opened the engine compartment lid and turned the cooling fan by hand. I could feel the fan rubbing the fan housing. How could this be? I just installed this brand new Valeo alternator a year ago. Did I have the fan belt to tight? I used five shims between the pulley halves and one behind the washer, this gave me about 5 mm of belt deflection which is recommended by the Bentley repair manual. Is the Bentley repair manual incorrect? Should I have used all six shims between the pulley halves?
pete3799 09-03-2016 09:09 AM
Did you actually take the belt off and spin it?
john walker's workshop 09-03-2016 09:12 AM
Possible cracked fan housing. Happens a lot. Try it with the belt a tad looser for now.
martidj 09-03-2016 09:29 AM
Thanks for the reply John, I noticed a crack in the housing when I replaced the alternator, wasn't a problem at that time. I will remove the alternator and see what I find.
impactbumper 09-03-2016 11:09 AM
worse case, the Valeo unit should have warranty also.
86 911 Targa 09-03-2016 11:18 AM
shims.
Did you install the woodruff key correctly?
FYI, I used three shims on each side for our M/Y 86.
pm me as needed.
Best,
Gerry
zedsn 09-03-2016 01:47 PM
I tend to leave my belt a tad loose because it does tighten up the hotter it gets.
martidj 09-03-2016 07:22 PM
pete3799,
I should have said I removed the belt. I'm glad this happened at home.
Bill Douglas 09-03-2016 08:06 PM
I have my belt a lot more loose than that. It doesn't seem to slip or flap around.
RAW911 09-03-2016 08:19 PM
+1 on what John says!
Check the struts on the alternator shroud for cracks. Your bearings may be OK.
http://forums.pelicanparts.com/uploa...1472958903.jpg
http://forums.pelicanparts.com/uploa...1472958921.jpg
Replacement aluminum shrouds are available from our host. R&R is an easy project.
911obgyn 09-04-2016 07:39 PM
When I took my alternator in to get it rebuilt the guy at the shop said he was having problems getting anything other than chinese bearings, I have had mine in for 2 years now and run my belt just a tad loose and use the Porsche belt, it fits best.
911obgyn 09-04-2016 07:42 PM
When My bearing went it sounded like I was being followed by a jet plane.
martidj 09-05-2016 08:07 PM
You are right Gerry, the Woodruff key was not installed correctly by me. I was lucky this happened at home. This could have been a very expensive repair.
