dmart2rp
Angry New alternator bearings failed only one year after installation
The other day I backed my 911SC out of the garage parked it and turned off the engine. After a couple hours I started my 911SC to return it to the garage when I hear grinding noise coming from the cooling fan. Immediately I turned off the engine to investigate, opened the engine compartment lid and turned the cooling fan by hand. I could feel the fan rubbing the fan housing. How could this be? I just installed this brand new Valeo alternator a year ago. Did I have the fan belt to tight? I used five shims between the pulley halves and one behind the washer, this gave me about 5 mm of belt deflection which is recommended by the Bentley repair manual. Is the Bentley repair manual incorrect? Should I have used all six shims between the pulley halves?
Old 09-03-2016, 08:18 AM
pete3799's Avatar
Did you actually take the belt off and spin it?
Pete
79 911SC RoW
Old 09-03-2016, 09:09 AM
Possible cracked fan housing. Happens a lot. Try it with the belt a tad looser for now.
206 637 4071
Old 09-03-2016, 09:12 AM
dmart2rp
Thanks for the reply John, I noticed a crack in the housing when I replaced the alternator, wasn't a problem at that time. I will remove the alternator and see what I find.
Old 09-03-2016, 09:29 AM
Cars Ruined My Life
impactbumper's Avatar
worse case, the Valeo unit should have warranty also.
Old 09-03-2016, 11:09 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
shims.
Did you install the woodruff key correctly?
FYI, I used three shims on each side for our M/Y 86.
pm me as needed.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-03-2016, 11:18 AM
I tend to leave my belt a tad loose because it does tighten up the hotter it gets.
Old 09-03-2016, 01:47 PM
dmart2rp
pete3799,
I should have said I removed the belt. I'm glad this happened at home.
Old 09-03-2016, 07:22 PM
Bill Douglas's Avatar
I have my belt a lot more loose than that. It doesn't seem to slip or flap around.
Old 09-03-2016, 08:06 PM
+1 on what John says!
Check the struts on the alternator shroud for cracks. Your bearings may be OK.
Replacement aluminum shrouds are available from our host. R&R is an easy project.
Old 09-03-2016, 08:19 PM
When I took my alternator in to get it rebuilt the guy at the shop said he was having problems getting anything other than chinese bearings, I have had mine in for 2 years now and run my belt just a tad loose and use the Porsche belt, it fits best.
Old 09-04-2016, 07:39 PM
When My bearing went it sounded like I was being followed by a jet plane.
Old 09-04-2016, 07:42 PM
dmart2rp
You are right Gerry, the Woodruff key was not installed correctly by me. I was lucky this happened at home. This could have been a very expensive repair.
Old 09-05-2016, 08:07 PM
