'73 911 T Targa
Put anything on trans drain and fill plugs before re-installing?
I just drained my trans oil and I'm about ready to put in the new oil. I'm wondering if I should put anti-seize or something on the plugs before putting them back in?
Also, is there a torque spec for the fill and drain plugs?
Old 09-05-2016, 03:42 PM
That's fond- just deglaze
Here you go. A Bentley Manual is a good investment.
Old 09-05-2016, 03:56 PM
Driver
Noah930's Avatar
I have never put anything into/onto those two plugs, and I have never had any trouble having them back out while driving, or be too tight to remove upon the next fluid change. Just torque to spec with a crush washer.
1990 Black 964 C2 Targa
Old 09-05-2016, 03:58 PM
I believe the 915 Specs will still apply for a '73!
Sorry- I just realized Bentley didn't produce a manual pre-1978.
Old 09-05-2016, 04:07 PM
'73 911 T Targa
My drain plug and fill plug don't have a shoulder that would accept a crush washer, it's more of a tapered plug like a pipe plug. They came out fairly easily, but just wanted to see if it's normal practice to prevent them from seizing.
Old 09-05-2016, 04:44 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Regular servicing?
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 09-05-2016, 05:11 PM
I believe it is common practice to install those dry.
(I'll admit to cleaning the threads really well and putting a little Curil-T on there. Most of it squeezes out on install.)
steely's Avatar
I agree - the oil they block acts as a lubricant.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 09-05-2016, 05:34 PM
Spiderman
Jesse16's Avatar
Really, no crush washer ?? Not familiar with that situation. In industry, tapered threaded pipe plugs nearly always would have a seal material applied, either a paste/liquid or basically teflon tape.
I would use two or three wraps of teflon tape back where the threads actually are engaged after tightening. Stay away from the tip if that protrudes into the housing. There is no pressure or much temp so seems that would work fine. No need to go really tight. Can't use a liquid in this situation as there is oil on everything. Again, no pressure.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 09-06-2016, 07:20 AM
