-   -   help decoding my engine #6292249 (http://forums.pelicanparts.com/porsche-911-technical-forum/927995-help-decoding-my-engine-6292249-a.html)
G50911 09-05-2016 07:42 PM
i have a project car that has the engine # 6292249 and i'm having trouble figuring out if it had weber carbs or mechanical injection. from what i found it's from a 1969 911E (i think).
can anyone help confirm?
matt930s 09-05-2016 08:50 PM
E's were injected.
MattR
G50911 09-06-2016 07:26 AM
thanks matt. can you or anyone confirm the engine is in fact from a 69 E?
ossiblue 09-06-2016 07:32 AM
Originally Posted by matt930s (Post 9269625)
E's were injected.
MattR
Yes^^.
However, number 629XXXX can also refer to a 79 SC engine. Check the engine number. A 69 will have a 901/xx number and a 79 will have a 930/xx number.
G50911 09-06-2016 07:35 AM
how can i confirm this?
ossiblue 09-06-2016 08:00 AM
If you're referring to my post, you can confirm your engine number by simply reading it--located on the flat portion of the case, just to the right of the vertical stamping for the serial number.
In the pic below, the green arrow points to the location of the serial number, and the red arrow points to the location of the engine type number.
http://forums.pelicanparts.com/uploa...1297769201.jpg
If you want to confirm the possibility that the 629xxx could be a 69 or 79, you can reference this site:
Fahrzeug-Identifizierung
G50911 09-06-2016 08:08 AM
thats perfect ossiblue, thanks!
