help decoding my engine #6292249
i have a project car that has the engine # 6292249 and i'm having trouble figuring out if it had weber carbs or mechanical injection. from what i found it's from a 1969 911E (i think).
can anyone help confirm?
1967 911 (Azzuro Thetys) - #308439 1971 911 (PTS Black) - Built 3.6 Sleeper 1989 911 (Grand Prix White) - Cabriolet Bone Stock |
War Vet
E's were injected.
MattR
Dr. Phatt |
thanks matt. can you or anyone confirm the engine is in fact from a 69 E?
Yes^^.
However, number 629XXXX can also refer to a 79 SC engine. Check the engine number. A 69 will have a 901/xx number and a 79 will have a 930/xx number.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
how can i confirm this?
If you're referring to my post, you can confirm your engine number by simply reading it--located on the flat portion of the case, just to the right of the vertical stamping for the serial number.
In the pic below, the green arrow points to the location of the serial number, and the red arrow points to the location of the engine type number. ![]() If you want to confirm the possibility that the 629xxx could be a 69 or 79, you can reference this site: Fahrzeug-Identifizierung
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 09-06-2016 at 08:04 AM.. |
thats perfect ossiblue, thanks!
