Jocke's Avatar
Send a message via ICQ to Jocke
Someone!! I need help with a thing regarding my mirrors.
Hey Guys!
I need to get the feet separated from the rest, is the screw on the pic the right way to go?? or maybe itīs not even a screw..
Is there some kind of special tool for it?
"the mirror are from the 964 series"
/Jocke
Jocke Andersson
Reach me on ICQ - 317860713
Porsche 930 -77 SOLD
Modified, one of a kind in Sweden.
Check out my car @: http://members.cardomain.com/jocke
Old 01-04-2003, 01:48 PM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
It's not easy but YES that will seperate the two pieces. Use an allen wrench and turn CCW while holding the top part of the mirror. Be carefull though it's spring loaded and only needs to turn about 45degree before releasing.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 01-04-2003, 01:52 PM
PUSH on it like crazy while turning. When you don't feel your hands anymore, you are getting close to the right pressure needed.
GeorgeK
Old 01-04-2003, 01:57 PM
Jocke's Avatar
Guys you are incredible.
In less then 10 min. and I got an answer.
/Jocke
Jocke Andersson
Old 01-04-2003, 02:03 PM
Kevin Stewart's Avatar
Take the mirror out first i believe you stick a small screw driver in that little hole in the bottom and slide a large ring to one side youll know by trying both ways which way to go, Kevin
Old 01-04-2003, 02:19 PM
1.367m later
KevinP73's Avatar
It may be easier if you have a friend sit down and hold the mirror firmly between his thighs while allowing the pressure your exerting to push the mirror into the seat cushion. It really takes a LOT of pressure to get it to release. Don't try to clamp it a vice, you'll surely damage it. Just be carefull, if your hand slip's, your helper is likely to end up on the painful side of the adventure.
Once you have it seperated, you'll find a nylon or a cast metal split ring in the assembly. When it comes time to re-assemble the mirror you'll be tempted to leave the split ring out. Resist the temptation otherwise the top of the housing will flop about and rattle
Old 01-04-2003, 03:16 PM
search around in the bolt bin and find a longish bolt, the head of which fits into the nut on the mirror. clamp the bolt real tight in a vise, sticking out sideways, then lean into the bolt real hard and turn the mirror with your hands. takes some muscle.
206 637 4071
Old 01-04-2003, 03:26 PM
Jocke's Avatar
Seems like I have to do some work-out tomorrow to be able to push that thing in... or out... or how I should say it..
/Jocke
Jocke Andersson
Old 01-04-2003, 05:51 PM
