Someone!! I need help with a thing regarding my mirrors.
Hey Guys!
I need to get the feet separated from the rest, is the screw on the pic the right way to go?? or maybe itīs not even a screw.. Is there some kind of special tool for it? "the mirror are from the 964 series" /Jocke
Jocke Andersson Reach me on ICQ - 317860713 Porsche 930 -77 SOLD Modified, one of a kind in Sweden. Check out my car @: http://members.cardomain.com/jocke |
1.367m later
It's not easy but YES that will seperate the two pieces. Use an allen wrench and turn CCW while holding the top part of the mirror. Be carefull though it's spring loaded and only needs to turn about 45degree before releasing.
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
PUSH on it like crazy while turning. When you don't feel your hands anymore, you are getting close to the right pressure needed.
GeorgeK |
Guys you are incredible.
In less then 10 min. and I got an answer.
Thanks /Jocke
Take the mirror out first i believe you stick a small screw driver in that little hole in the bottom and slide a large ring to one side youll know by trying both ways which way to go, Kevin
1.367m later
It may be easier if you have a friend sit down and hold the mirror firmly between his thighs while allowing the pressure your exerting to push the mirror into the seat cushion. It really takes a LOT of pressure to get it to release. Don't try to clamp it a vice, you'll surely damage it. Just be carefull, if your hand slip's, your helper is likely to end up on the painful side of the adventure.
Once you have it seperated, you'll find a nylon or a cast metal split ring in the assembly. When it comes time to re-assemble the mirror you'll be tempted to leave the split ring out. Resist the temptation otherwise the top of the housing will flop about and rattle
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. Last edited by KevinP73; 01-04-2003 at 02:20 PM.. |
search around in the bolt bin and find a longish bolt, the head of which fits into the nut on the mirror. clamp the bolt real tight in a vise, sticking out sideways, then lean into the bolt real hard and turn the mirror with your hands. takes some muscle.
Seems like I have to do some work-out tomorrow to be able to push that thing in... or out... or how I should say it..
/Jocke
