Where the hell is the horn?
![]() So today I have been trouble shooting my none working horn on 911 sc 12v to horns they work Rely check it works Steering wheel push check, where the hell is it ?? All I have is a wire hanging in there ,can someone post a photo of what I'm missing, and /or where I can find the part I need Many thanks bob ![]() |
On an SC they are behind the front bumper, passenger side I think?
Check our host for the slip ring for the horn contact.
Slip Ring for Horn Contact 91134709905 - Genuine Porsche - 911-347-099-05 | Pelican Parts |
you ground the wire.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Ok so I'm thinking the bare wire is coming from the slip ring which is in place at base of boss
If I ground this wire I hear the relay click so horn should sound ? What is the mechanism for grounding wire behind the horn pad? |
The three brass studs that secure the plastic pad retainers are the ground contacts. The single ground wire connects to the underside of the pad if the connector is not broken.
One wire is ground--the other to the horn button.
I would say the longer wire goes to button the other to ground On my 81 coupe the horns are below the passenger side bumper Ernie
----------------------------- Ernie 81 SC |
Thanks everybody for input
Cpa I think it must be this underside pad connector that I'm missing ? Anyone able to put up an image of it on here for me please Bob |
Oh got it now the horn pad is the switch but on my pad the wires connector is broken off flush with pad I've dug into the pad a bit to find enough to solder new wire too
Thanks for help bob |
