Car running rough
Went on a drive to the local mountains today and after about 40 minutes of freeway driving when I got off the freeway the 911 was running rough. Stopped for a few minutes and then it ran fine the rest of the day.
The car has been running fine I just added gas the day before.
The engine is a 81 3.0 SC.
I'm thinking it is the fuel accumulator.
Any help would be appreciated.
Ravi
1974 914 2.0
1975 911s 3.0
2014 Cayenne GTS
2016 Cayman GTS
Old 09-10-2016, 06:56 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Check the plugs too,one may have popped off.
'85 Carrera Targa
PCA/POC
Old 09-10-2016, 07:17 PM
I will check that today. Thanks for the advise.
Ravi
1974 914 2.0
1975 911s 3.0
2014 Cayenne GTS
2016 Cayman GTS
Old 09-11-2016, 05:48 AM
theiceman's Avatar
im not sure why you would think it was the fuel accumulator as its way to early to rush to judgment.
see if the problem reoccurs and check some easy stuff first . cap/rotor/ plugs. plug wires, bad gas.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 09-11-2016, 06:32 AM
Trying not jump to conclusions. Thinking it might be related to a vapor lock and it seems to be fuel related. After I stop the car and start it again it runs fine. I have checked the plugs and the cap and it seems fine.
It might be bad gas and sees if happens again before I tear everything apart.
Ravi
1974 914 2.0
1975 911s 3.0
2014 Cayenne GTS
2016 Cayman GTS
Old 09-11-2016, 07:47 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by 914Ravi911 View Post
Trying not jump to conclusions................
I am still sensing a wee bit of conclusion jumping..........
Before you tear into the fuel systems these cars are not prone to vapor lock. The accumulator is a shock absorber for fuel pump flow. It's secondary purpose is to keep pressure on the downstream side of the system. If that function is failing, your car would start poorly after ten minutes when it's warm as the pressure has bled down and it's too hot for the cold start valve to function.
My bet something electrical is messing with fuel. Fuel pump relay or Lambda relay.
How hot was it when you drove?
1981 911SC Targa
Old 09-11-2016, 08:31 AM
I'm putting $1 on the lambda relay or it's wiring. Disconnect it and see it if still runs rough.
Old 09-11-2016, 09:56 AM
Sticking distributor advance?
Old 09-11-2016, 10:09 AM
Fuel accumulator.........
Ravi,
Your fuel accumulator is not the culprit for your problem/s. If you could make your engine start, cross out the fuel accumulator and focus on some other things like FV relay, ignition system (distributor, plugs, wires, etc.), or even a bad batch of fuel. Keep us posted.
Tony
Old 09-11-2016, 10:43 AM
RETIRED
Joe Bob's Avatar
Run a bottle of Techron thru it, check plugs and injector connections.
2012 ML350 3.0 Turbo Diesel
Old 09-11-2016, 10:44 AM
That will be the first thing I do.
Ravi
1974 914 2.0
1975 911s 3.0
2014 Cayenne GTS
2016 Cayman GTS
Old 09-11-2016, 04:40 PM
You got a batch of bad gas. Put a bottle of dri gas in the tank to absorb the water.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 09-11-2016, 04:59 PM
I had the same problem a few months ago. Car is tuned up so I added a bottle of the real deal, Techron and it cleared things right up!!! Get it at Pep boys, Walmart, Auto Zone.
Old 09-11-2016, 05:50 PM
Check distributor cap and wiggle rotor to see if there is too much play in distributor shaft.
Old 09-11-2016, 08:50 PM
Bill Douglas's Avatar
Umm, you just reminded me. My SC had been running roughly, especially once it got really warmed up.
I found the distributor cap wasn't seated quite as well as it could have been and now that's sorted it runs like a dream again.
Old 09-11-2016, 09:03 PM
