air-cooled 911: engine bay heat/sound pad
Has anyone used this product or something like this as a replacement for the engine bay heat/sound pad? I have an '87 911 Targa.
Thermo-Tec Automotive - 48" x 72" 1-SIDED THERMO thanks, Dave |
Good find. The double-sided material/version is probably similar to what Appbiz uses for their custom cut and trimmed ones. I have one installed and not only did it make a noticeable difference it fit so well like a glove that I didn't even use a spray adhesive. Used about eight 3" strips of strong adhesive velcro on the upper/mid portion along with the factory metal tabs, nice and snug with no sag.
1988 Porsche 911 Carrera Coupe - Engine Miscellaneous - Page 7 ![]()
______________ '88 911 Coupe '98 Spec Boxster '85 380SL Benz -Euro |
I'd have to cut this product to spec. Where did you find the advesive velco strips?
Dave |
Spiderman
That looks like it would work fine. The App Biz one I got is more a black foam backing. Mine in place for many years, no adhesive required. What you're paying for is for it to arrive 95% cut properly to fit. Mine is foil out just like the photos which I think looks best.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Good to see ya Jesse, fun time at Lime Rock this spring!
I used the Thermo tea on a Turbo with good results, reflect heat better than the stock unit.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Is it me or why do we want to reflect heat back into the motor compartment...I thought this was a sound deadening pad engineered to keep the cabin a bit quieter....
1984 Carrera Targa |
Registered Minimalist
Anyone with the Appbiz delux heat pad (The black one) have a pic of it installed in the engine bay? Thank you in advance
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
