-   -   Solid state DME Relay conversion ? (http://forums.pelicanparts.com/porsche-911-technical-forum/928709-solid-state-dme-relay-conversion.html)
uwanna 10-18-2016 03:00 PM
Originally Posted by mysocal911 (Post 9323653)
Remember, most all OEMs, e.g. Porsche Cayenne, still use a mechanical relay in critical
areas such as activating the FP.
The real bottom line is a mechanical relay is CHEAPER than an electronic one! Makes a big difference when producing thousands of cars.
Tori 10-18-2016 03:24 PM
FWIW, i just installed one of these solid state DME's last week. I think i see less cranking but it's not night and day difference. Im sure some of that is vehicle dependent.
Now, i did have one strange issue this past weekend. The car crapped out on me, and i couldn't hear the fuel pump powering up with the key like normal. One the side of the road i tried the key several times with no FP sound. I checked the relay, pushing on the connector and twisting wiring. After that it started up and hasn't missed a beat since. Now i'm nervous about this relay too. :(
DRACO A5OG 10-18-2016 08:42 PM
Oh wonderful, contact F9T.
Brother Tori, you did not have a spare in the car, you must always keep one just incase. :D
Tori 10-18-2016 10:43 PM
what makes you think i didn't have a spare ? Hell, i have two. :rolleyes: The first spare i bought shortly after buying the car, (a regular mechanical type) and then the original that was in the car when i bought it after buying the solid state version.
Didn't need either though as after i touched and wiggled the thing it started working...... :confused:
DRACO A5OG 10-18-2016 11:10 PM
That's weird, glad it worked out.
I still can't get use to the pump prime. :eek:
Tori 10-26-2016 11:03 AM
FWIW, i emailed FT9 just to let him know about my momentary issue with the relay. I only wanted to make him aware that it happened early on in the ownership in case it ever happened again.
He promptly emailed me back saying he was sending a replacement that day, along with a prepaid shipping label to ship the old one back.
NOW THAT'S SERVICE ! :D
scarceller 10-26-2016 11:17 AM
The very best spare relay to have in the glove is a gutted old faulty relay that has pins 30,87 and 87b all hardwired/jumper together. If you do this you will instantly power up the DME and the Fuel Pump the very minute you plug that test relay into the harness. Of course you can't leave things like this but in a pinch it will get you home.
I have exactly this in my glove box at all times. It can even get you out of other potential issues with the ignition switch and such.
DRACO A5OG 10-26-2016 11:32 AM
Outstanding!
Arne2 10-26-2016 11:34 AM
+1. I made a hard wired jumper to bypass mine when it failed in the garage, in the middle of my move to a new house. I had to drive the car, but had only owned a couple of months and had not bought a spare relay yet. The jumper worked so well that I don't have a spare relay, just the hardwire rig, which is always in the glovebox.
DRACO A5OG 10-26-2016 11:42 AM
Another alternative is to resolder the old or bad ones with high % silver content solder, should be bullet proof for life.
Mrdi 11-11-2016 04:42 AM
1) Do the pins on the SS DME relay come ready to install? 88 Carrera G50
2) How do you ground yourself to the chassis for installation?
jlex 11-11-2016 06:27 AM
1) yes
2) just touch an unpainted metal part on the car to discharge any static electricity you may be carrying so you don't unintentionally zap the relay's electronics.
david.avrahami@ 11-11-2016 07:27 AM
solid state DME RELAY
I would like to have one the solid state DME RELAYS,, discussed here, for my 87 carrera.
Unfortunately, The Mfg/supplier of the relay does not ship to Canada...
Would someone will undertake to ship it to me ? I will purchase it and get it sent to you
and send you directly your incurred costs.
Here is my e mail address : david.avrahami@bell.net 416-833.6693
The volunteer, please send me your home address and e mail address and phone number. I will respond with my address as well.
GH85Carrera 11-11-2016 07:45 AM
Originally Posted by jlex (Post 9286560)
I ordered the non-priming model. Was a bit afraid of hydro-lock or flooding if the fuel pump was running each time the key was turned in a no-start situation. I suppose the designer figured out how to deal with that but I just wanted to be on the safe side if I had to crank the engine multiple times due to a no-start situation. I guess I'm just paranoid... :rolleyes:
I have started to watch how I start my 911 now that I have the 3 second prime version of the DME. I have to deliberately pause to hear the pump run if I want to hear it. When I forget and just start the car normally, it is just twist the key and there might be a 1/10 of a second of extra prime if that. And the fuel system has a return line and the injectors don't fire unless the engine is rotating. There is no reason to not get the pump prime model.
DRACO A5OG 11-11-2016 09:18 AM
Originally Posted by jlex (Post 9355279)
1) yes
Ditto, use old bag to store back up relay. :D
jlex 11-11-2016 10:36 AM
I had previously modified my mechanical relay to test the fuel pump/pressure when I had some concerns about that with my '85. Took the case off & jumpered two of the pins using a fused wire and an intermittent (button) switch. When I wanted to power up the fuel pump w/o turning the car on to test the pump and pressure, I'd just reach under the seat & press & hold the button. Nice manual way to pressurize the system especially when the car sat for weeks. Looking back, it's probably better to allow the car to crank a wee bit longer while its building up fuel pressure as that allows time for the oil to circulate a bit more before it fires.
uwanna 02-14-2018 12:29 PM
Just found a big plus for using the F9T pre-prime DME relay. After four days of non stop rain and drizzle I went to start my 3.6 motor and it just cranks with no start. I suspected moisture in the dizzy, but then remembered I had the pre-prime DME relay. I'm so used to just cranking
and having it start I didn't pay attention that there was no whir of the fuel pump that occurs when you turn on the ignition.
Rethought things, and when I turned the key on before cranking, I didn't hear the fuel pump run like normal. I then reseated the DME relay and exercised the key several times and voila I heard the fuel pump come to life and the motor fired up!
I saved a great deal of trouble shooting time I would've had to have done if I didn't have the pri-prime feature. I assume I had a flakey contact problem in the ign switch. It sure is reassuring to hear the fuel pump run for three seconds when you turn on the key.
Checked his web site, and it shows he is sold out of his electronic DMEs, wonder if he just quit making them or is just sold out as it shows. Would be too bad if he quit building them as it was a life saver for me.
http://www.ftech9.com/new-products/911-ssr-pp
pmax 02-14-2018 01:21 PM
This reminds me of the good ole spread the pins of the fuel pump relay hack.
uwanna 02-14-2018 01:32 PM
You may be correct, but the pre-prime function not working led me right to the problem, whearas without that function I would have been guessing whether the problem was fuel, spark, moisture or something else.
198491132 02-15-2018 07:28 AM
I had no idea these were around, I need one! Web site says sold out and no model form 84 3.2. I sent email with an inquiry. Any other place to get find one?
mepstein 02-15-2018 09:35 AM
I picked up mine from eBay.
uwanna 02-15-2018 10:07 AM
A pelican named Ftech9 is the man who developed these solid state
DME relays. Perhaps send him a PM asking about future availability.
By the way, he hasn't posted since March of 2016.
Here's his original post from when he was developing them. Just did a search on Ebay and found none.
http://forums.pelicanparts.com/porsche-964-993-technical-forum/873271-solid-state-dme-relay-beta-testers-wanted.html
mxtx 06-10-2019 09:24 AM
very interested in solid state, and reading through all of this debate to pump-prime or not.
do we know how it works, or doesn't work, with an SW chip installed?
my assumption is the SW chip was designed with a stock non-pump-primed system in mind and to introduce more info to the system could be confusing but i really don't have any real knowledge on this. any experience is appreciated, thanks.
Lyle O 06-10-2019 10:18 AM
I have had the solid state relay with pump-prime for several years (including when I had a Steve Wong chip), and it works flawlessly. I love this relay.
Koizumi 06-10-2019 10:30 AM
I went for the fuel-priming version as well. I also have a Steve Wong chip.
I do keep a working spare DME relay and 2 red relays in my glovebox.
Works wonderfully. I highly recommend the fuel priming version. As previously stated, hearing the pump whirrr before ignition is a crucial troubleshooting issue that can easily be checked off of a no-start diagnosis.
uwanna 06-10-2019 10:35 AM
I also have had the SS pump prime relay installed for several years with an after market chip and it works flawlessly. I assume the 3 second prime function is built into the DME relay using a time delay circuit and has nothing at all to do with the ECU or chip.
Get one they are great, and you can forget any DME relay worries!
wrxnofx 08-09-2019 10:05 AM
I got the pump priming version of this relay about 2 months ago. It seemed like initially the crank time on my '87 was WAY shorter. Now, not the case anymore.
I have also had 3 separate occurrences where the engine dieseled after shutting off the car. Maybe 1 or 2 seconds each time. I never had this problem before installing this relay. Anyone else?
I reached out to the guy but got crickets, so I thought I'd ask here if anyone else has had this problem.
Missed Approach 08-09-2019 05:27 PM
Hi @wrxnofx- I think we both installed ours at the same time- no issues yet. That dieseling is quite odd. I do have a spare DME (OEM) if you want to swap it and check!
Ralph3. 08-09-2019 07:00 PM
I have the non priming version on mine and have been happy with it. Installed mid 2017, no issues.
Ralph3. 08-09-2019 07:04 PM
Sorry I have a 964
Ctopher 08-09-2019 07:08 PM
I’ve had the priming version on my car for about a year this August. I have not had any issues with the car but the dieseling is something I’ve noticed from time to time both before and after the solid state DME. In all cases that I remember I slowly turned the key to turn off the car, almost as if power was pulled and added back. Since I realized that I’ve done a quick turn off of the car and have not had another occurrence. Not sure if others have noticed that turning the key slowly causes this.
CTopher
GH85Carrera 08-10-2019 09:57 AM
The web site for his solid state DME is Focus 9 Technology, LLC
I bought the 2 second prime version, and have had it for two years and over 11,000 miles with flawless operation.
uwanna 08-10-2019 10:08 AM
I have used the prime version of the Solid State DME relay for three plus years on my 964 transplant motor with not a single problem. Still keep a spare original DME relay in the glovebox just because. The SS DME has been one of the best buys ever for my 911.
ClickClickBoom 08-10-2019 05:49 PM
Anecdotal, fuel pressure is fuel pressure, the fuel injected into the engine is through the injectors. The fuel pump is either on or off.
evilfij 08-10-2019 09:57 PM
Non-prime on a 993 here. Two years, no issues, stock one is still in the car as a spare.
Roswell 08-11-2019 08:06 AM
Is there a current preferred source for a SS DME?
Canada Kev 08-11-2019 10:14 AM
He has them in stock currently.
wrxnofx 09-03-2019 06:27 AM
And yet my engine's behavior has returned to normal having swapped back in the original relay.
ClickClickBoom 09-05-2019 05:21 PM
The fuel injectors are either on or off. The relay only controls the electricity powering the pump. Your after running is coming from some where else.
phelix 03-02-2020 07:12 AM
Can anyone explain why the prime and non-prime versions of the relays appear to have different pin orientations with respect to the mounting tab? I have emailed Joe but had a confusing reply.
This photo is from their website.http://forums.pelicanparts.com/uploa...1583161923.png
