-   -   Solid state DME Relay conversion ? (http://forums.pelicanparts.com/porsche-911-technical-forum/928709-solid-state-dme-relay-conversion.html)
phelix 03-02-2020 10:17 AM
All cleared up now; in the photo above the pin orientation on the non-prime version is correct and that's how they're being shipped.
nene 03-02-2020 04:11 PM
And finally after more than 30 years, my relay gave up and stranded me like 2 miles away from home. I had a brand new relay from URO which worked, but it sounded like my car was running on 3 cylinders.
Finally made it home and immediately ordered a Solid State relay which I receive today, but have not installed it yet.
Here is a pic of the relay!!!:eek::eek::eek:http://forums.pelicanparts.com/uploa...1583194124.JPG
TheKneebiter 10-17-2020 04:12 PM
I can fix that. How did the solid state relay work for you?
nene 10-19-2020 12:17 PM
No issue with solid state and loving it! The fuel pump Priming is a big plus!
UROParts 10-19-2020 02:25 PM
10/26/20 EDIT: Good news, Nene sent us a PM saying, "the issue was NOT your DME relay, it was a bad injector."
We sold our first-generation relay 911 618 154 00 from 2011 to late 2019, and have been shipping our redeveloped second-generation relay since late 2019. The first-gen relay did have issues, which is why we discontinued it and started fresh.
brighton911 08-15-2023 04:22 PM
I can say with 100% certainty that you will not find better after sales service from the good people at F9T. My fuel pump prime relay gave a bit of trouble and even though I think it may have been out of warranty, Joe responded within minutes of my inquiry offering a replacement. That kind of treatment is rare and very welcomed, many thanks for a fine product and super service!
pmax 08-15-2023 07:46 PM
Not sure a quicker start if that's the plus is a win.
A couple more revolutions can be beneficial before firing.
mysocal911 08-15-2023 07:53 PM
They fail too! So always a good idea to re-solder the original DME relay and keep it in the car as spare.
SpyderMike 08-15-2023 09:15 PM
Yes, a couple of those joints look questionable. Reflow them all and give it a try.
jlex 08-16-2023 04:53 AM
Have to agree with Pmax.... I'd rather see a bit of oil distribution with a few cranks before the engine starts. Don't they say most engine wear is at startup due to lack of oil pressure? I've bought the Focus 9 solid state DME relay years ago and it has never failed me. I got the one that does not have the pump primer feature for that reason.
mysocal911 08-16-2023 05:50 AM
A real measure of reliability is when they reach over 10-15 years in service like the original simple two relay DME relay.
GH85Carrera 08-16-2023 06:19 AM
There is no better test of reliability than the test of time. I bought my Focus 9 relay when they first came out in 1996 or so. Since then I have put over 30,000 miles on it.
I do indeed carry a spare German made DME relay in the glove box along with spare fuses, and a piece of string trimmer sting to get into the fuel door if that handle breaks. I have never needed any of those items yet, but I have them with me all the time.
My 1985 OEM DME from relay lasted until 2004, and 115,000 miles or so. I am at 191,000 miles now.
mysocal911 08-16-2023 06:31 AM
Actually, they were being Beta tested in 2015;
http://forums.pelicanparts.com/porsche-964-993-technical-forum/873271-solid-state-dme-relay-beta-testers-wanted.html
GH85Carrera 08-16-2023 07:45 AM
Originally Posted by mysocal911 (Post 12069048)
Shows my memory gaps! Whoops. I was 10 years early.
Mine is the early version, with no diagnostic lights on it like the new ones. I did not write down the date of the installation in my log of work done on the car, and estimated from other things done back then. I had to estimate, and wow, was I off. After 27 years of ownership llots of projects, they do blur together.
gerry100 08-17-2023 12:01 PM
Is the solid state DME still available and at what price?
darrin 08-17-2023 12:07 PM
https://www.ftech9.com/new-products/911-ssr
pmax 08-17-2023 12:42 PM
Yep, batteries are cheap.
I'm curious just how fast the engine starts with the fuel prime. Mysocal probably knows this on the top of his head assuming it fires up on first spark. Even in "modern" cars, it takes a sec or two.
mysocal911 08-17-2023 09:29 PM
Never tested the "solid state" relay.
Most all stock 911 3.2s I've tested over 25+ years start in 2-3 seconds.
Ctopher 08-18-2023 07:07 AM
Yes it fires pretty which….guess a revolution before it fires up. I never really paid much attention but she does fire up fast.
CTopher
