				SC brake rebuild upgrade
			I have never touched the brakes on my 82 SC.  They work good, but I think it is time to go through the entire system.  I plan on changing all the existing rubber/flexible lines.
				Also considering upgrading the front brakes to the wider 84 up Carrera rotors and calipers and just rebuilding my rear SC calipers with a set of new rotors. Any thing I need to know and order before I start on this project. I would like to have everything on hand before I start this project. Any and all info appreciated.  |
			 Max Sluiter
			If it ain't broke don't fix it. Just change the rubber lines if they are old and flush the fluid, check the pad/rotor thickness.
	1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance  |
			My understanding is that SC brakes are already over powered for stopping an SC.  Upgrading to different rotors/calipers doesn't accomplish much.  But replacing the rubber and wear parts sounds like a wise plan, especially if you don't have records of when it was last done.
	Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.  |
			 Reiver
			That makes sense if you have increased hp by a great deal....otherwise stock is more than adequate if in good shape.
			You can 'over brake' and get a twitchy and break away/lock up situation.
	De Oppresso Liber Strength and Honor 5th Legion  |
			 RETIRED
			Do the maintenance and leave the rest alone.  Slotted or drilled Zimmerman or ATE rotors are a good idea.
	1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel  |
			PMB Performance does a great job rebuilding calipers, they look and hold up better (the crud you see on your calipers is actually corroding them) and not too big a job to DIY
			+1 on new rubber lines, check rotors/pads and change if necessary
	Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe  |
			I just upgraded my pads to more track oriented units.  I'm stunned at the performance of the basic stock components.  It's a very good system for the SC, I wouldn't waste my time upgrading the front rotors / calipers if the rest of your car is basically stock.
	1980 911 SC - Black on Red Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html  |
			 Fleabit peanut monkey
 I put the early Boxster fronts calipers on with 3.2 rotors 12 years ago. A different feel. Can't say they brake better as have never worked either kit hard enough. Have swapped them on and off again. I say put the hoses on. Flush and do everything you can to get every spec of air out. Getting the air out was THE biggest step change in my brakes I have experienced. Before and after the Boxster "upgrade". If you go the 3.2 route, and I am just talking, do the whole nine yards if possible, including master cylinder.
			1981 911SC Targa Last edited by Bob Kontak; 09-02-2016 at 11:27 AM..  |
			Make sure you replace the calipers with the bleed valve up!  (If you swap them side for side by accident, the bleed valve will be down - which is bad.)
	Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ???  |
			Thanks for all the responses.  However, I failed to mention in my original post that I have installed steel turbo flairs on the 82.  I also increased the wheel size to 17x9 on the rear and 17x7 on the front with larger tires all the way around..  I love the turbo look of a Porsche.
	Since my original post I have secured and rebuilt a set front and rear of Carrera calipers. Ordered new Carrera vented Zimmerman front rotors and a set of emergency brake shoes for the rear. Figured I would replace them when I had everything apart. Question - What rear rotors do I purchase. Carrera or SC. Thanks again for previous responses. I am not a rookie at building cars, but a rookie at building a Porsche. I do have a complete set of factory Porsche manuals to help me along the way. Thanks again.  |
			 Occasional User
			please delete
			Vince 2015 Boxster S, Black & Black 1989 Carrera Silver Coupe, Silk Grey - sold 2009 Cayman S White, Full Cocoa - sold 1972 911E Silver Coupe, Pepita & Black - sold Last edited by Cook&Dunning; 09-13-2016 at 07:09 AM..  |
