1968 transmission question
I have a 1968 fixed window targa with matching numbers motor. However the transmission is not matching what I have in my COA.
Current transmission has the following markings;
Number 7191763
Case number 901.301.101.0R
Then near the case number there is a circle with a 38/68
Can someone with access the specsheets decifer these numbers? Thank you
Old 09-13-2016, 03:58 PM
Peter Zimmermann's Avatar
7 = trans for 6 cyl engine
1 = std ratio 5-speed
9 = 1969
1763 = sequential number
Perhaps your car was originally a Sportomatic, and was converted using a transmission that was as close as possible to being market correct.
Keep the Shiny Side UP!
Pete Z.
Old 09-13-2016, 04:18 PM
According to the COA my car originally came with transmission 3280711 (902/1)
I don't believe that was a sportomatic.
What about the other numbers? What does the 33/68 refer to?
Old 09-13-2016, 04:29 PM
Any significance to be learned from casting number?
Old 09-13-2016, 05:30 PM
pors1968's Avatar
your trans case is it alu or mag.
Old 09-13-2016, 05:32 PM
djpateman's Avatar
3280711 (902/1) : pretty standard Al case 5 speed for 1968
gears A 11:34 F 18:34 M 22:29 S 25:26 X 28:24 P&R=7:31
7191763 (901/07) : standard Al case 5 speed for 1969
gears A 11:34 F 18:34 M 22:29 S 25:26 Z 29:23 P&R=7:31
Case number 901.301.101.0R is for Al case
The casting date does not mean much except to me probably.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 09-13-2016, 06:03 PM
