Carrara oil cooler threads
Bought this oil cooler from this site from a guy in Boston. A small section of hose and the nut were
Still attached. My mechanic had to cut (dremal) off the nuts as I could not get them to move. Are these threads salvageable? I brought the cooler to a few machine shops and they say probably not salvageable. Any ideas?
Thanks.
Old 09-13-2016, 01:57 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Threads.
With the correct metric dye-maybe.
I would take the cooler to a machine/weld shop
and have the fitting replaced.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-13-2016, 02:27 PM
Auxiliary thermostat threads......
Malmos,
Test fit the 36-mm nut with a cone shaped end compression fitting (tube piece). If the compression fitting sits tight and snuged, it is doing the sealing. A compression test will show or reveal any leak at the joint.
Tony
Old 09-13-2016, 02:29 PM
