89 coupe G-50 transmission mounts
Hello, I have an 89 coupe with a G-50 transmission. I would like to know if the mounts in the photos are supposed to be as shown or should the rubber at the top of the mounts be touching the top cupped washer. It seems to me that they should. I have checked the center bolts and they are tight. Both sides are the same, this is the drivers side mount. I appreciate any insight in this situation.
Thanks, Scott
There is a very specific washer that goes on the top. Looks like the bottom but with a raised center section that goes against the body hanger.
Bruce |
So is mine missing this washer? There is a cupped washer at the top, is that it or something else?
Thanks |
Member 911 Anonymous
It depends, did you take the pic with the car on the ground or raised?
BTW, please delete the double posting
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
On the ground. Thanks
Tried to delete double post but couldn't.
