Porsche 911 SC, SAAB SPG
3.2 oil pressure reading <1 bar at idle when cold
I haven't driven the car very much over the past six months, but everything was fine the last time I drove it. I started the car up this week and noticed the oil pressure gauge was barely above 1 bar. Also revving the car up to 3,000 rpm doesn't really change the pressure reading. It goes up a little bit, but never over 1.
I disconnected the sending unit wire and the gauge reads above 5 bar so I know the gauge is working. I replaced the oil pressure sending unit today and the reading is exactly the same... The oil pressure warning light is off and the car doesn't sound like it has low oil pressure, but I can't be sure. I'm not sure I can check the actual pressure at my house with my current set of tools. Is there anything else I can do besides bring it in? Can I check the oil pressure relieve valves or something?
Jeff C Last edited by jcunning; 09-14-2016 at 07:02 AM.. |
Grounds?
Put an ice pick down into the connector between the plastic cover so you can tighten the wire on the pin of the pressure sender.
Make sure there is no green inside Bruce |
When the connector broke on my sending unit wire, I just used a butt-splice connector. I crimped it to the wire, and then slid the other side onto the pin from the sender. It now works perfectly.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
I forgot to mention I did check the wire and it was broken as well. I replaced it with a butt connector. I will double check my work on this part.
Jeff C |
