Po-Porsche
Need help picking M&K exhaust
Hey all,
I've got an Euro model 1984 911 Carrera 3.2. I live in California so a cat has been added in order to pass SOG. Otherwise, the car is totally stock. I'd like to swap out my exhaust for a 2-in, 2-out system and think I've decided to go M&K. However, I've found two different models with a significant price difference but I don't understand what the real difference in the exhaust is. First is the "MKM29" for $795. Tailpipes spacing is 12″ on center with 2.5″x8″ tailpipes https://mkexhaust.com/dual-inlet-911-s/ Second is "MKM29ST" for $1,196. Tailpipes spacing is 11″ on center with 2.5″x8″ https://mkexhaust.com/911s-street-muffler/ The $400 difference can't possibly be for the 1" difference in tailpipe spacing. What am I missing? What's the difference here? Which is "better"? I'm mostly looking for an improvement in exhaust tone. I'd like a lower tone, louder 'growl' but I also need to pass smog. Any advice would be greatly appreciated! Last edited by dirtyduck; 02-22-2021 at 10:30 AM.. |
The street version has baffled pipes. Whether that accounts for the total cost delta, I cannot answer. It may have to do with tuning and/or other R&D to comply with emissions testing. Call or email Brian, he is extremely easy to reach and will help you decide which muffler best suits your needs. Whichever you choose, rest assured you are getting the highest quality product. I have no affiliation nor am I a “money is no object” guy. However, I will spend my money on quality products and customer service and will support and promote those enthusiasts/vendors that provide such support to the community.
Ass-engine Nazi slot car -- PJ O'Rourke |
per M&K website, "our street version [is]designed to pass CA and track 95dB sound requirement when used on stock engines. A less aggressive idle than our sport version but retaining that raw sound that just rips when you get on the cam! Average cabin sound level at cruise is similar to stock."
Are you changing out headers as well? If not, believe you'd want a 1 in muffler, like this one. https://mkexhaust.com/single-inlet-911s/. |
if you change the headers you won't pass CA smog...
1971 914-6 GT 3.6 1974 911 1976 911S leaf green backdate 3.2 |
RETIRED
Dual exhaust tend to drone at 3K rpms....right in the sweet spot.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Po-Porsche
Awesome help guys, many thanks.
Right, if I don't change headers that means 1-in, for the 2-out, I totally missed this. And, since I need to work within the CA SMOG tolerance, I suppose swapping out headers is out of the question. Also, I've read a little about the drone issue with dual exhaust. I saw two Carrera's with dual outlet yesterday on the ACH canyon run and both sounded awesome. But, does anyone know if the baffles fix the drone? And, is the drone really that big of an annoyance or is it really just more about personal preference? |
Drone will wear you down. I have a dual out M&K with SSI style headers. One pipe is capped internally and the other has a Quiet Riot baffle. I run at Limerock which has a very low sound restriction (80db?) and have not had issues. No drone with one capped. You can’t tell by looking at it.
Crotchety Old Bastard
First thing you gotta do is decide if you are staying with the OE heat exchangers or going with headers. If you want to remain 100% smog compliant and wish to maximize power we have a CARB CA compliant active exhaust system for the Carrera.
If you have a cat and want a different look and sound we have the single inlet GT3 and S tailpipe configurations along with the standard single out mufflers. These same CARB cats can be plugged in and used with our tuned headers however that would not be visually correct as you would have 2 cats instead of 1 (go figure). There are many differences between our Street (ST) and Sport (S) mufflers. Both are dual inlet and both can have S or GT3 tailpipe spacing. Sports are designed for guys who like it loud, but there are drawbacks to this. The more loud a muffler is the less it hides. If you have a slight miss it will now be audible, if the engine is out of tune you get less than good tones, and yes it the harmonics of the induction cams and exhaust system don't cancel you get drone. Quiet the muffler and all this is muted or goes away. That is the reason for the Street Series Mufflers. They are more quiet and utilize baffling that disrupts the pulse harmonics that cause drone. They are also physically a bit larger to reduce back pressure that is added by baffling.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
![]() I have a dual in dual out with my 993 headers. I also got dual silencers from car chemistry to keep the sound reasonable. |
The sound is quieter than my old Triad muffler but semi wife approved. Haven’t dynoed the car with this setup, but horsepower wasn’t the main goal here. |
You're in SoCal. Let's connect so you can hear my M&K Active Exhaust pre-muffler and 1 in/out...
![]() ![]() We can discuss some of the different exhaust configurations I've tried.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Frank,
Are you going to bring that exhaust cap to market?
MKM28 Sport. Absolutely love it. Great quality!
Here's another CA friendly option that also keeps heat -
Stock heat exchangers, M&K cat by-pass for off highway track days and M&K one in one out muffler. When required I easily swap the by-pass for my original cat. Very similar to Frank's above, with the exception of my heat is back dated (simplified) and Frank has the fancier muffler with a vac assisted muffler by-pass.Sounds great, zero drone, and substantially lighter than stock.
1978 SC Targa |
I have some thoughts about how to make one but usually when I think of something "new" someone has already made it!
1982 911SC |
Alternitively, I'm going to try packing the tips with stainless steel wool made for this purpose. |
No way. That's a custom piece!
What I did not want to do was bring a scratched tip to market.
https://www.amazon.com/gp/product/B0085PCREY/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
