French Import
zippy_gg's Avatar
Recommended tire pressure.
For those running Conti 205/55-16 and 225/50-16 on stock rims for street use, what pressure are you running?
The sticker on my car show inflation for 15 inch rims; also as tire technology has evolved quite a bit since 1986 I am looking for real life values and not sticker or tire manufacturer recommendations.
The car is stock 1986 cab.
Thanks!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 09-26-2016, 01:19 PM
gtc gtc is offline
abides.
gtc's Avatar
Sticker on my car says 29/36 PSI. I run my tires at 32/39. YMMV.
Graham
1984 Carrera Targa
Old 09-26-2016, 02:03 PM
Flyin' blind
I have conti extreme contact d/w in those sizes and run recommended psi: 29/36
Cheers!
Thom
89 Coupe
Old 09-26-2016, 02:39 PM
After I got my car lowered to euro height, the shop told me to run 34/40.
ken
87 targa
Old 09-26-2016, 04:32 PM
Your question
Well if your taking your girl out for a comfort drive go with factory spec, now if your going to drive it like you are stealing it add 5 to 7 to each tire
Be safe
82 SC Twin Plug 3.2 SS ,46 PMO
Old 09-26-2016, 04:41 PM
88 Carrera, Guards Red
azhodge's Avatar
Love this discussion. like to hear other opinions. I always thought the factory numbers were not optimal.
Old 09-26-2016, 06:34 PM
Diss Member
Quicksilver's Avatar
There is no "correct" tire pressure. Different tires, uses, conditions, and preferences all work out to different tire pressures.
A conventional tire wants a higher pressure. Most slick or minimal tread R tires want a low pressure. For aquaplaning resistance in rain you want a higher pressure and for a comfortable ride you want lower pressures. (And why the hell did everyone go to tires with damn near zero sidewall on passenger cars?!!!)
The only way to optimize pressures for your use is to test them on a skidpad or some other constant radius turn where you have a controlled situation that allows you to safely push the tires to their limit to see which end of the car is working.
If you don't need that much then just use what is on the door. (For 16x6 and 7s that is 29/36.) For rainy weather you can just pump them up to the maximum on the sidewall.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 09-27-2016, 05:03 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Tire pressures.
For our '86 with 7's & 8's 205's & 225's,
I pump up the tires to 35F & 40R,
let sit overnight,
then bleed them down to 29F & 36R.
Good/even tire wear.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-27-2016, 06:41 AM
scarceller's Avatar
I have a 84 factory widebody and it came from the factory with 7" front 8" rear and those exact tire sizes 205/55/16 front 225/50/16 rear.
The sticker on my car says 29PSI front 36PSI rear.
So that's another factory data point from a widebody factory car.
I run 30PSI front 35PSI rear, handles well on the street.
Running Bridgestone RE760 street tires.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 09-27-2016, 06:48 AM
French Import
zippy_gg's Avatar
The sticker on my car says 29PSI rear 26PSI front.
I run 30PSI rear 35PSI front, handles well on the street.
Sal, am I reading correctly that you run much higher pressure on the front than the rear?
Gilles & Kathy
Old 09-27-2016, 08:44 AM
I typically set mine at or slightly above the recommended pressures (205/55 and 225/50 Conti DWS), but what I am puzzled by is the people here who are running significantly *lower* rear pressures. This on a car with a significant rear weight bias.
'80 SC Targa
Avondale, Chicago, IL
Old 09-27-2016, 09:16 AM
Tire pressures.
For those who desire a softer ride, I suspect that lower tire pressures helps.
But, what about even rear tire wear?
Gerry
1986 911 Targa.
Only in L.A.:
Old 09-27-2016, 09:43 AM
French Import
zippy_gg's Avatar
These are the tires I am using.
BTW I replaced the worn out shocks with all around Bilstein Heavy Duty and did not change the torsion bars. All bushings were also replaced. So I am not looking for very high performance although I enjoy spirited drives just as I do on my Beemer.
Thanks!
Gilles & Kathy
Old 09-27-2016, 09:54 AM
scarceller's Avatar
Sorry my mistake,
Factory spec for my car is 29front 36rear I fixed the prior post.
But I run 30front 35rear.
Sal
1964 356SC (SOLD)
Old 09-27-2016, 10:30 AM
Diss Member
But I run 35front 30rear, so yes higher pressure in the front tires than the rear is the norm for most auto specs.
Those tire pressures are about the most dangerous thing I have seen posted here!
The "norm for most auto specs" are for cars that have about 60% of the weight in the front because almost every car made is front engined. The front pressure isn't dangerous, it is just unbalanced compared to almost any acceptable rear pressure. If I had arm or shoulder issues I might run elevated pressures in the front to reduce steering effort.
The reduced rear pressure is just plain dangerous. It will cause excess heating of the tire from the increased quantity of flex. (mostly in the sidewall and shoulder where it is most dangerous!)
60% of the weight of a 911 is on the rear wheels plus the rear wheels need to deal with the constant torque of propelling the car. A 911 is one of the best engineered cars in the world and deciding that you will "re-engineer" the critical tire pressures based on the fact that completely dissimilar vehicles have different settings is either arrogant or insane.
This advice can KILL someone. Period.
Old 09-28-2016, 07:35 AM
scarceller's Avatar
Thanks for catching my mistake, I have that backwards I run 30 front 35 rear, sorry about the confusion. I fixed the prior posts.
And to be clear the factory sticker says 29front 36rear.
Sal
1964 356SC (SOLD)
Old 09-28-2016, 08:04 AM
Diss Member
Wholy crapparino! You had me scared for your safety. Glad to see it!!
Old 09-28-2016, 08:22 AM
IROC's Avatar
I was at a PCA tech session years ago where a Yokohama representative talked about this very subject. His response was to use the factory recommended tire pressures unless you have modified the car substantially or are using tires significantly different that what came stock.
My car came with 185/70-15s front and rear. I now have 225/45 and 255/40-17s on it. I still use the factory recommended tire pressures and they work just fine.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 09-28-2016, 08:24 AM
for AX (not often these days) I run 35 rear, 33 front. I'm on stock wheels/tire sizes. 205 on 6?" fr and 225 on 8" rear all by 16" dia. I don't change for the street so that's what I end up running on the street also. Tires are wearing even as much as I can tell.
Sold: 1989 3.2 coupe, 112k miles
Old 09-28-2016, 08:31 AM
Why such a high pressure in the rear? These cars are tail happy, and I would think lower rear pressures give a larger contact patch?
I run 35/35 on the track, before the even starts.... I am sure its much higher after....
Old 09-28-2016, 12:02 PM
