cary's Avatar
DELETE : Power Windows ??
Has anyone removed the power windows from their car ( SC + ) ?
I'm not one to shy away from difficult project.
What would it entail ?
I'm looking at putting RSA door panels. I would like to remove the power windows before I do that.
PS : This is my 911th post, Cool.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 01-05-2003, 08:41 AM
Chuck Moreland's Avatar
911th. Are you gonna change your name
I think you just need to change to the manual regulators. Everything else should work.
Chuck Moreland - elephantracing.com - vonnen.com
Old 01-05-2003, 08:50 AM
pjv911's Avatar
Send a message via AIM to pjv911
I installed power windows in my 69` . I wasnt thinking of weight savings earlier in the time the car was being built. It was a direct swap however. All the bolt holes and provisions are in the doors for power or manual windows. I plan to switch back to manual either this winter or next. I believe the power regulators were redesigned in the mid 80`s. My 79` 930 regulators were different than my 86` carrerra units. The 86 units are much better designed. I would imagine the manual regulators were redesigned at that same time.
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 01-05-2003, 08:51 AM
Cool
there is some kind of a window regulator pin that goes bad.. a stronger pin is available that's made of a stronger steel.. may have to match up the old soft pin to a new stronger pin.. when the old soft pin goes kaput the window travel is kaput.. it's easy to tell the new design regulators from the old style.. eyeball both before buying an old style used one.................Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-05-2003, 11:16 AM
Easy
Just change the power regulator to a manual one it bolts up 1 hour job seriously. make sure you get window cranks.
the wiring harness is by itself to the fuse box. Use the now unused relay hole for something like a oil cooler fan.
Old 01-05-2003, 03:12 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
cool....I plan on doing the same to mine, don't need no stinkin power windows! If anyone has pics of this type of project, please post them.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 01-05-2003, 03:19 PM
I'm also getting rid of my heavy electric motors for hand cranks. It would be nice to see some pictures. I understand pictures better than the written word. John
1996 740 il
Old 01-05-2003, 05:41 PM
pjv911's Avatar
Looks like an excellent opportunity for a tech article. Who got the time ?
Kurt Williams
Old 01-05-2003, 05:43 PM
cary's Avatar
Here's the PP catalog page
Window Regulators
Having trouble raising your window? Tired of driving without getting some fresh air? Replace your broken window regulator with a brand new one. These often deteriorate and fail after many years of use and abuse. Replace your window guide channels too while your replacing your regulator. Note: When replacing the early-style parallel arm regulators, you need the late-cross arm style, plus the adapter kit. See Technical Bulletin #7
Manual Window Regulators
Coupe Window Regulator, left, 911 (1974-89)
C-542-929-03 $126.30
Coupe Window Regulator, right, 911 (1974-89)
C-542-930-03 $126.30
Targa Window Regulator, left, 911 (1974-79)
C-542-929-42 $153.70
Targa Window Regulator, right, 911 (1974-79)
C-542-930-42 $175.70
Window Lifter Rail (driver side), 911 (1970-79)
A-542-045-23 $67.53
Window Lifter Rail (passenger side), 911 (1970-79)
C-542-046-23 $67.53
Window Lifter Rail (passenger side), 911SC (1980-83)
C-542-058-42 $63.25
Window Lifter Rail (driver side), 911SC (1980-83)
C-542-057-42 $46.70
Window Lifter Rail (driver side), 911SC/911 Carrera (1980-89)
C-542-057-00 $35.70
Window Lifter Rail (passenger side), 911SC/911 Carrera (1980-89) C-542-058-00 $31.35
I don't see the adapter kit. Do any of you guys see it ?
Cary
73 914S 2.0 AG
Old 01-05-2003, 05:51 PM
Lifter rail was the same {power and manual in my 911sc}
Old 01-05-2003, 07:19 PM
pjv911's Avatar
THATS THE LATER STYLE REGULATER. BUT THATS ABOUT ALL THAT SCAN IS WORTH. CAN YOU CLEAN IT UP ANY ?
KURT WILLIAMS
Old 01-05-2003, 08:43 PM
cary's Avatar
Sorry, that's not much help.
Maybe a photo would be clearer. I haven't mastered the scanner, yet.
Cary
73 914S 2.0 AG
cary's Avatar
Tech #7
I made a mess of that. LOL. Here is #7 from my parts book. Sharpened. We'll see.
It don't like me the second time. Say's TOO BIG. It's only 632. So I don't know what I did. ??
Cary
73 914S 2.0 AG
Old 01-05-2003, 08:57 PM
cary's Avatar
One more time
I GIVE UP..........
Cary
73 914S 2.0 AG
Old 01-05-2003, 09:01 PM
cary's Avatar
OK, I'll use the back door.
Using Multiple
Cary
73 914S 2.0 AG
Old 01-05-2003, 09:09 PM
cary's Avatar
Still worthless..........sorry
Cary
73 914S 2.0 AG
Old 01-05-2003, 09:11 PM
Cool
I'll try
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-05-2003, 09:32 PM
Does anyone know of the total weight savings?
John
1997 993
2012 991
Old 01-05-2003, 10:19 PM
pjv911's Avatar
My guess is about 7 lbs combined . Maybe 10 lbs ?
Old 01-06-2003, 05:27 AM
