braking news
howdy all,
I am going to put a set of 930 brakes on a 70 S w/ an rsr body and 3.5 L twin plug motor, car will be primarily used on track but won't be a dedicated race car per se. Do you folks think it makes sence to go a master cylinder set up that allows adjusting the front to rear brake bias, if so how does one proceed on a modest budget if possible. Thanks as always, Phil |
JOT MON ABBR OTH
Phil,
I really don't know much, but I do know you will need a master cylinder that allows adjusting the front/rear bias. This will be necessary as you try and maintain control while braking. I was under the impression the stock 911 braking system has this ability, however you are wanting a track car which would require stronger/tougher brakes. I do not know how to do it on a budget and not be called an East Texas White Trash Redneck in the process. I'm sure someone else is already typing that response right now.David Certified East Texas White Trash Redneck 7 horses in the backyard Dog/Cat (very confused pair) Ford 3/4, Chevy 1/2 (forgot the '48 Farmall B) '83 Targa |
Phil.. reads like a great fun 911.. and Bill Verberg is real good on your subject.. he also has a web page.. maybe a PM to attract his attention.. enjoy..............Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
the adjustable pedals are great you can somewhat adjust the pedal hight, and also adjust front to rear biasing, you can also use a brake bias valve, some have screws and some have a lever these work fine, but will not give you more rear brake if you need more rear, i really dont think a rear heavy 911 needs more rear but you never know, i will say to get the brakes set up properly be careful and make sure you take it easy at first be cause if you go on the track and have to much rear brake you will find yourself doing 360's , The stock car guys and road course guys have a adjuster that they run up beside the seat, you will need one of these so you can adjust the brakes while you are on the track, i always forget which gives more rear or more front so I mark it on the dash(arrows left and right with f (front) on one side and r (rear) on the other), Have fun nice upgrade for a track car, Kevin
There is no "modest budget" method to go to a dual master setup on a 911. The Tilton setup is $750 and installation requires a lot of work. Check out Smart Racing Brake page for more info. Good luck on your project, sounds like a neat car, TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
Re: braking news
The 930 has very nice native bias due differential piston bores. You can keep your standard 19mm m/c or for better feel at the expense of higher effort get a 23mm ATE replacement.
