-   -   Another Valve adjustment question (http://forums.pelicanparts.com/porsche-911-technical-forum/93008-another-valve-adjustment-question.html)
scoll911 01-04-2003 11:32 AM
Quick Question?
I just finished adjusting 1 and I rotated the engine 120 degrees. I noticed 6 was very tight and while I was under there I decided to see if the feeler gauge would slide into 4. It did -- why would the gauge slide into 4 120 degrees past TDC (Z1).
All help appreciated.
john walker's workshop 01-04-2003 12:07 PM
it will slide into a lot of other ones too, but that's not what you need to worry about, just the next one in the firing order.
scoll911 01-04-2003 12:14 PM
Thanks John -- I was hoping you would reply
