HarryD's Avatar
Odd Tire Wear
I know the car is not a Porsche but it is made in Stuttgart.
Question for the brain trust.
Stephanie hit a curb with the Mercedes C300 and damaged one of her front tires. I needed to get it replaced. No biggie it was about 50% worn at 20,000 miles and it was replaced under warranty by the good folks at Discount tire. They checked the rear tires an found the centers worn to the wear bars (These have the same mileage, as the fronts).
Here are the pictures:
Left Rear tire:
Right Rear tire:
Front tire:
I try to run the tires year round at the recommended tire pressure on the door jamb.
Is this Normal?
I am thinking that I should lower the rear tire pressure by 3-5 psi to get the edges to wear at the same rate as the sides.
Thoughts?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-28-2016, 08:03 PM
twistoffat's Avatar
Get your alignment checked. Especially after hitting the curb it would be worthwhile. Excess rear wheel tire wear is not unusual on a rear wheel drive car but in your case its not even. Your camber on the rear needs adjusting but IŽd just get new tires and a full alignment done.
Old 09-28-2016, 09:33 PM
