-   -   Welding set rail bracket to tunnel (http://forums.pelicanparts.com/porsche-911-technical-forum/930664-welding-set-rail-bracket-tunnel.html)
guli 09-30-2016 02:21 PM
I need to do some welding on the passenger side of the tunnel. I know that the fuel lines run in the driver side conduit in the tunnel but what's on the passenger side?
Is there anything that I need to remove inside before weliding the seat rail support for a lowered seat?
Thanks!
jpnovak 09-30-2016 03:43 PM
main wiring harness runs in a channel under the top passenger side corner. Tread carefully. I don't think I would weld there unless the wiring was pulled through.
guli 10-01-2016 08:24 AM
Thanks. This is what I suspected.
NickP 10-01-2016 09:06 AM
http://forums.pelicanparts.com/uploa...1475337938.jpg
