Another 3.2L question .
Can i be helped connect these vacuums lines ?
Motor is 3.2l
All lines seems to be coming from throttle body and capped by the previous owner . See pictures and as always TIA.
Old 10-07-2016, 05:53 PM
One more
Old 10-07-2016, 05:55 PM
That Guy
Techno Duck's Avatar
1 - Hose goes to oil tank, near the oil fill tube. Its part of the oil tank breather.
2 - This is the thermovalve for the fuel vapor purge system; one line runs to throttle body, the other goes to the air valve which is located on the right side of the engine bay, also near the oil fill tube
3 - This goes to the same air valve noted above. Its right by the deck lid hinge if i remember right.
4 - Same as above
5 - This goes to the venturi tube for the brake booster
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-07-2016, 06:19 PM
I think I have the same problem.
L Jetronic parts missing
Old 10-07-2016, 07:03 PM
Thanks , I appreciate your prompt reply.
Old 10-07-2016, 07:04 PM
Dooodahman's Avatar
Also, save yourself a needless troubleshooting and do a search on "breather hose restrictor" and make sure you have one in the hose that goes to the oil tank near the oil fill tube before you put it all back together.
Andrew
1987 Carrera Cabriolet
1988 Carrera Coupe (RIP)
Gone are the days we stopped to decide where we should go......we just ride.
Old 10-07-2016, 07:25 PM
