Which engine to choose Poll
I can't decide on the engine upgrade, hoping you guys can help.
I want a bit more power. I go to an autocross Once a month. Option 1 Make a 3.4 Turbo out of my 3.2 $20,000 Option 2 Buy a 3.3 Turbo motor for $35,000 (will require 930 trans) Option 3 Buy a 3.8 RSR motor for $25,000 Option 4 Leave 3.2 as is and just do P/C's and heads? $8000 I have a 3.2 currently in my 1977 car. It began smoking a bit. 3.2 came back with 2 cylinders with bad leak down numbers. leak down numbers Cyl 1 - 50% Cyl 2 - 5% Cyl 3 - 5% Cyl 4 - 5% Cyl 5 - 5% Cyl 6 - 50% What i don't get is that the car pulls strong and last dyno it did 217hp out of the wheels with 964 cams. I get poping out of the exhaust on deceleration but thats about it. Another shop gave me a thinner oil before and my indy said that this engine needs 20w-50 for it not to smoke. But as soon as the oil will wear out it will start smoking again. ![]()
'77 Porsche 911 S Red/Cork Tan * Turbo Tail * 930 Steering Wheel* 17" Fuchs (r) * 3.2 * 915 * LSD * 930 Brakes * Elephant Racing Suspension * Turbo Tie Rods * Bilsteins Sports * Steve Wong Pre-Muff * B&B EXhaust * SW Chip on 4K DME PCA Last edited by axvel; 10-10-2016 at 11:52 AM.. |
porsher
How about a bone stock 993 3.6 motor?
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
I already bought a bone stock 993 engine, for 12k for another project. And then it turned in to additional $8000 worth of conversion parts from Patricks motorsports.
'77 Porsche 911 S Red/Cork Tan * Turbo Tail * 930 Steering Wheel* 17" Fuchs (r) * 3.2 * 915 * LSD * 930 Brakes * Elephant Racing Suspension * Turbo Tie Rods * Bilsteins Sports * Steve Wong Pre-Muff * B&B EXhaust * SW Chip on 4K DME PCA |
Why would you let your oil ''wear out'' ? Run 20/50, and change your oil every 3000 miles.
Keep thinking about what you want to do. |
seems to me that any option beyond a bone stock 3.6 will make your 915 transmission the next point of failure. How much more power are you after? Another option is to bore your 3.2 out to 3.4 (cheaper version from here is to stick with single plugs, more pricy to twinplug, but lets you get more power) or replace p&c with 3.5l (and get case spigots bored). This will not provide as much torque as the turbo option and will be (more) doable with a 915. Sal (scarella) has a lot of experience with injectors, MAF and software if you choose to go this route
Sounds about right, but the leak down kills me. And plus the need for more power is what drives me, forget about the slippery slope, i'm in mid flight already.
Very nice looking 911 . . .
I would say it all depends on your budget . . . and future use of the car . . . The 3.4 Turbo or 3.6L option will give you a lot more power - but this leads to other things $$$ . . I vote for rebuild 3.2 and enjoy the car . . . Regards, PS: Also, use some really good 15/50 ( oops ment 20/50) race oil - we use Amsoil . . .
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine Last edited by Sboxin; 10-10-2016 at 02:09 PM.. Reason: added info - correction to 20/50 |
see you're in LA, what are your emissions requirements?
Emissions are very strict, as you already know. The car is going out of state.
You can find someone eases project car for less than it would cost to do a monster engine. Just buy a 997 or 991 and have that much performance and an car that has the brakes, suspension and other goodies needed to make an entire car package. Sell the 911 as is and move on to a car that was designed for that much power.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I'm afraid of 997's because of IMS, buying a car and towing it to a indy to do IMS retrofit right away. And 997 turbo and gt3's are in 100k's
You might check with some of the POC race guys - they have a C 3.2 Race class the run Turbo wide bodies like yours and stock 3.2L engines - - they are pretty fast at the big Willow track.
A lot of their engines are built at Asse Motorsports in Fullerton - our race car came with a stock spec 3.2L built by them and it raced for 4 years and we sold the engine in good condition to another Pelican in Wisconsin. Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
Brando
Any turbo option will end up needing 930 or g50 gearbox. The torque will kill the 915. Unless you use low boost
Turbo powa! 1977 911s. it's cool |
3.4 Bigger is better
Go to a 3.4 or 3.5L. I did the 3.4L and am getting 260Hp. SteveW did the tuning on the engine and it pulls strong to near redline. If I did it again I would have gone to the 3.5L.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
Maybe just shift into 3rd ?
1986 Bosch Icon Wipers coupe. |
axvel -- are you sure you need work done on your engine? Specifically, what's its oil consumption like? Unless you're below, say 500 miles per quart, there may be another cause for your poor leakdown numbers -- also looks like you're running a premuffler instead of a cat (a cat will mask a LOT of oil burning). My point here is that if you're not burning through too much oil, you might be able to drive it for a while longer as-is while you determine best next steps for your car. That said, I'm in a similar boat in that I want more power for my carrera. In my case, I want to stay NA and am leaning toward a 3.5l twinplug conversion on my 3.2 and a ~20% increase in power. These will be some pricy horses, but I plan to keep my car (also need to pass colorado smog) and enjoy them for at least another 150k miles . . . .
Everyone talks about more horsepower but what your looking for is power/weight. It's a lot cheaper to reduce weight than add horsepower. I removed 250 lbs from my 72 911. Then what kind of driving are you primarily doing. Autox? Then your just looking at tires and low speed torque. A gear change will take care of that. Track days, well now horsepower is an issue but before that torque pulling out of the corners. I had a special cam ground for my 3.0L that lowered the torque peak while still making horsepower on my twin cam engine. Like I said power to WEIGHT. Mines 8.9:1 with only 245 hp.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
