the_win's Avatar
Question Why remove smog pump off 2.7l?
I have a 76 911S Targa. I've read some threads, saying that they removed the smog pump, from these kind of engines. I don't think it takes much horsepower from the engine, if any, and I would think that it would cool the exhaust gases, keeping the engine slightly cooler. Since the exhaust goes right pass the engine.
So why disconnect the smog pump?
Old 01-05-2003, 01:05 PM
Buy them, sell them
Adam's Avatar
Welcome to the board!
As I understand, it's quite heavy. Seeing that you don't live in CA, it's also a superfluous piece of engine bay equipment that restricts access to the left side cylinder bank.
I'd remove it (mine's gone), but keep it in a box for the next owner.
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 01-05-2003, 01:09 PM
adding air to the exhaust just as it exits past the exhaust valve actually makes the exhaust hotter, the object of which is to help burn any unburned fuel that otherwise would be discharged into the atmosphere. cars with air pumps run just the same as those with it removed. they do get in the way of valve adjusts and sparkplugs, and the engine does look better with it gone. emission standards for the engines that had the pumps are fairly loose, so most can be adjusted to pass smog without it, unless there's a visual test required.
206 637 4071
Old 01-05-2003, 01:11 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
I have a pump for sale if anyone is interested...like new!
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 01-05-2003, 02:21 PM
Buy them, sell them
Adam's Avatar
K9,
I've got some old warped Magnesium valve covers and a crummy 5-blade fan for sale too...
Old 01-05-2003, 03:43 PM
makaio's Avatar
If you remove it (which I recommend if you don't need for smog), make sure to plug diverter valve. Other wise it will run like crap(ask me how I know). Of course, that's if you don't remove the whole assembly.
Old 01-05-2003, 03:48 PM
Montana 911
k9handler's Avatar
Cool Adam,
I can trade you a slightly used tie-rod end, a half used set of squeaky brake pads, and a broken clock! ha ha
H.D. Smith
2020 Yamaha YFZ450R
Old 01-05-2003, 04:01 PM
dtw dtw is offline
GAFB
How about the rusty metal boogers I just sliced out of the nose of my new '72? Original, vintage, Porsche sheetmetal; with that "patina" of age.
Several BMWs
Old 01-05-2003, 04:13 PM
Buy them, sell them
Adam's Avatar
Hmm. I'm also looking to "unload" my old school-bus sized original steering wheel... I'll swap you for the rusty boogers!
Old 01-05-2003, 04:16 PM
Zeke's Avatar
Win, In the '80s,I had a 2.7 totally rebuilt here in CA at Andial. At first, I ran the pump with the belt off. Then I put the belt on for smog. Then, sometime later, I took the belt off. Pretty soon the pump was almost frozen. I kept asking Arnold at Andial what I am doing to the motor putting it on again, off again. He said no big deal but he also said that he was supposed to tell me to leave it on because of being licensed as an auto repair facility in CA. As far as I could tell, he didn't care if it was hooked up or not and I couldn't tell any difference either. I know this contradicts what JW said, but that is the way it was. In the end, I ran the belt. Owned the car for 15 years.
Old 01-05-2003, 05:35 PM
dtw dtw is offline
GAFB
Noooooooo! I seem to have accumulated 3 or 4 of those things...I think they multiply when I turn out the light...each one more scratched, worn, and rusty than the last.
Several BMWs
Old 01-05-2003, 05:43 PM
I removed the smog pump when I upgraded to Carrera tensioners...and my car runs much better. I keep it handy for my once-a-year inspection.
- Dr. Scott
______________
'77 911S Targa
Old 01-06-2003, 04:50 PM
