bcheney's Avatar
Porsche Cayenne Battery linked to deaths in FL
I know this may be the wrong place to post but I just saw this local news story here in Orlando. Check this out...never knew a Cayenne engine battery is under the passenger seat?
Medical examiner confirms suspected cause of deaths in Turnpike mystery | Local News - Home
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 10-04-2016, 05:00 PM
Banned but not out, yet..
RSBob's Avatar
Prolly on its 3rd battery. Defective altinator possibly cause over charging? My Audi 200 turbo Quattro had its battery under the passenger seat just like my old bug.
Old 10-04-2016, 05:14 PM
Send a message via AIM to fintstone
Mine is under the driver's seat. It is vented.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 10-04-2016, 06:45 PM
RSBob's Avatar
It's been nice knowing you
Old 10-04-2016, 07:09 PM
There is literally nowhere else to put a full-sized battery. The engine fills every inch of the engine compartment. I replaced the first one about 3 years ago without incident.
They used to put them under the back seat of VWs...
Nice knowing you too.
Old 10-04-2016, 08:35 PM
The news report I read said it wasn't the original battery, so it's possible that the vent hoses were left off at the last battery change. In my limited experience I have found battery vent tubes frequently not connected to the battery on cars I have worked on
Old 10-04-2016, 09:07 PM
Functionista
manbridge 74's Avatar
I see them with all the typical issues that are also dangerous with having battery mounted somewhere else. Missing hold down clamp (in a wreck a battery jammed up into metal hood will cause a fire), vent tube to battery missing or not hooked up, the vent assembly that provides actual air to battery compartment not hooked up etc.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 10-05-2016, 05:47 AM
76 911S Targa
The VW bug had the battery mounted under the back seat.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 10-05-2016, 08:15 AM
Functionista
It's sad that these people died but one can learn from it. A rotten egg smell is not normal. No matter how slight it might seem.
Jeff
74 911, #3
Old 10-05-2016, 06:01 PM
I smell lawsuit and new laws with batteries being prohibited from being installed in cabin.
Old 10-06-2016, 05:36 AM
theiceman's Avatar
i would imagine one of the issue is people not wanting to pay the big dollars stealerships want to charge you for oe battery so pick a " compatible" one up from a big box store. When they realize the vent line connection is not there or incompatible they leave it off.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 10-06-2016, 06:31 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
I had a Bug, whenever I had some of my football team members in the back seat there would be a burning hair smell while driving around. Never put 2 and 2 together, the luck of youth.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 10-06-2016, 10:23 AM
rokemester's Avatar
Again with Bugs it was often owner error. People forgot or lost the black battery cover which protected the positive and negative battery terminals from shorting out on the rear seat springs. It was the horsehair you'd smell.
Very unfortunate result of not using manufacturers OE parts. I wonder if Porsche and dealers stress the importance of proper battery and battery installation?
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 10-06-2016, 06:13 PM
Chain fence eating turbo
Can't believe I'm saying this, but this may be warranted
Old 10-06-2016, 07:11 PM
Functionista
You do not need a Porsche brand battery in a Cayenne. Many dealers install a "direct fit" equivalent battery. You do need to have some common sense about how things work to properly install one.
Batteries have been installed inside vehicles since almost forever. No lawsuit here. Or at least a successful one. I believe I read they had hydrogen sulfide on their urine so I suspect this was happening for some time and not just due only to the accident.
Jeff
74 911, #3
Old 10-06-2016, 07:14 PM
michael lang's Avatar
None of us know if the people that passed away were at a Porsche dealership service dept or even an independent and they were told that the battery has a problem. So for all we know, someone may have attempted to avoid this tragedy from happening.
Mercedes Benz also puts the battery in the subfloor under the pass seat in the R-Class, ML and GL as well.
Mike
'89 CARRERA
#402
Old 10-07-2016, 12:12 AM
