Old Headlight Seal Glue - There Has to Be A Trick To Get It Off
I am in the middle of replacing my headlight seals, and whomever did this prior was very "liberal" (gasp) with the black adhesive. So much so, that it shows beyond the normal seal position...unsightly and interferes with seal placement. Any tricks to removing this old adhesive?
2018 991.2 Cup Car
2014 997 GT3-R
2010 997.2 Cup Car
1989 911 3.2 Coupe
Old 10-05-2016, 04:17 PM
Occasional User
Cook&Dunning's Avatar
This looks like a homegrown application - I am thinking the PO smoked some homegrown, then went to town with adhesive. If this is your 88 Coupe, with H5's - or earlier H4's for that matter - I think you should have a factory rubber gasket, and no goop.
Vince
2015 Boxster S, Black & Black
1989 Carrera Silver Coupe, Silk Grey - sold
2009 Cayman S White, Full Cocoa - sold
1972 911E Silver Coupe, Pepita & Black - sold
Old 10-05-2016, 05:14 PM
Agreed. Just hoping someone has a miracle solvent to get the crap off.
2018 991.2 Cup Car
2014 997 GT3-R
2010 997.2 Cup Car
1989 911 3.2 Coupe
Old 10-05-2016, 06:14 PM
911SC Tinkerer
merlinfe's Avatar
Maybe Goo Gone? If it was a non painted or exposed area I'd use a heat gun on low and at a distance to very lightly heat the stuff and aid in getting it off. Just be careful not to mess up your paint.
- Steve
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 10-06-2016, 02:38 AM
WPOZZZ's Avatar
Goo gone, Goof off or you can try WD40. Bug and tar remover is another thing to try.
Old 10-06-2016, 03:01 AM
wayne robson's Avatar
old seal
Automotive paint shops sell Prepsol, Autosolv,Clean and prep,Different names.
it is what painters use before final paint,and it is safe on your paint.
Old 10-06-2016, 06:05 AM
Yea, that stuff is NOT what the factory or anyone with brains would do. Good luck getting it off. WD-40 does wonders on many forms of goo.
Get new OEM type rubber seals when you finally get that crap off.
Old 10-06-2016, 06:21 AM
If it is flexible, it might be weather strip adhesive (looks like it to me).
If so, suggest you try 3M 38987 Specialty Adhesive Remover.
'76 2.7-->3.2
Old 10-06-2016, 10:16 PM
I'd give WD40 a try first. If that fails my next option is always mineral turpentine. It is amazingly capable at dissolving old glues and sticky stuff in general, and of course paint safe.
'70 911T (AKA Bottomless Pit) - Undergoing restoration
'13 Audi A4 1.8T - Surprisingly fun means of getting to work
Old 10-07-2016, 02:15 AM
If that is the glue for windshields, good luck. That stuff won't let go.
Old 10-07-2016, 03:28 AM
Peanut butter. Seriously
1969 911E SOLD
2002 996 Cabrio
1995 993 Carrera 4 SOLD
Old 10-08-2016, 08:48 AM
