Clearly understand. Thank you.
Fat butt 911, 1987 Last edited by rnln; 10-10-2016 at 01:03 AM.. |
Around here, the highest can find in most gas stations is 91. If that is true, it is very inconvenience.
Fat butt 911, 1987 |
Rescuer of old cars
Perhaps it varies from year to year. My '84 manual is very clear - 87 minimum, 92 recommended. As I noted, I've never put less than 92 in it, but apparently the stock chip timing map on an '84 can tolerate 87.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Diss Member
One detail not touched on here is what other differences there could be between the premium and regular grades of gasoline when our cars were produced.
It used to be common for manufacturers to use a better additive package in their "premium" grade gasolines. For example Chevron first introduced Techron in their premium gas. They later added it across the whole range but they still were adding more to the premium grade. They finally changed so it is the same across their whole range. (Not sure if there are differences in other parts of the additive package.) The point is that at the time when they wrote the manuals for the Carreras there was an additional reason to select the premium grade when filling your car. I don't think it is consideration anymore but in the 70s and 80s it still was.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
ASE Master Tech - 35 yrs
in any case - for my '89 3.2, i am suddenly interested in this a lot since i recently got one of Steve's chips, programmed for 91 AKI (28-pin 082 DME) - and am experiencing some pinging at tip-in at almost any rpm, and under load at lower rpm on hills (hot summer days in CA) - similar to Arne2's report here - comparably my spare '87 DME (24 pin 050) with the oem "-302" chip has no such issues (Steve wrote elsewhere that this is one of the best Factory chips) - also no problems when running a spare '84 DME i am exploring the possibility that maybe i just got some "bad 91 gas" when i filled up to test that new SW chip, but it's disconcerting to say the least ![]() y'all may want to read what Steve Wong wrote about this octane issue 3-26-2008 ![]() 87 CLC Octane Question given what Steve wrote in above link - i should theoretically be able to run 87 AKI (CLC) with 302 chip ??? (or for sure,with that '84 DME) just for reference here is another link with several of Steve's comments Steve Wong Chip Advice .
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
