-   -   Instrument LIGHTS experiment - Part 2 (http://forums.pelicanparts.com/porsche-911-technical-forum/93175-instrument-lights-experiment-part-2-a.html)
APKhaos 01-05-2003 08:48 PM
The second round of of tests are done, and we are getting somewhere [but not fast, I know].
The first experiment showed that there were a few problems to solve, and that there was a decent chance of a result that would be much better than the dull glow of the stock gauge lights....for those who want it.
I've tried LED products from around ten vendors. The original plan was to locate a stock array which could be grafted onto the european bayonet base. As TRE's work confirmed, thats a dead end. Light tubes are duds as well - major instrument mods required to the to make that work.
Turns out that suitable LEDs need to be set up in an array [I'm using 4 per 'bulb']. These LEDS need to be massaged to improve their beam spread. Its all a bit labor intensive at present.
So, the results so far:
http://forums.pelicanparts.com/uploa...hite Panel.jpg
The coverage of the most instruments is far better than before, but the speedo and clock are not there yet. The problem stems from the obvious fact that VDO built their instruments first, then tried to find a spot to drop in a bulb or two. Lighting design is a primary design goal for contemporary auto instrument panels, but it was a poor cousin back in the 50s when VDO designed these babys.
Did somebody say RED?? Since so many people mentioned red as an alternative, I decided to include red in this set of tests. They really look good [subjective, I know] and appear to provide a far more even light spread.
http://forums.pelicanparts.com/uploa... Red Panel.jpg
http://forums.pelicanparts.com/uploa...2 Red Tach.jpg
So, whats next? A few things, actually.
First, I'm trying to find a source for the european bases so I can quit de-glassing stock bases for each of these test LEDS.
Second, the next test will feature LED arrays specifically set up for a particular gauge. The Tach array will be slightly different to the Speedo array - beam alignment, spread etc. Should finally get a nice even coverage this way.
Finally, I'm determined to get this right before much longer. Not sure if it will ever be a DIY project, but will be trying to make it so.
Now I know how the Prince of Darkness felt.
AAARRRGGGHHHH ... sorry about the wide screen bungle - my bad.
bell 01-05-2003 08:59 PM
wow.......i like the red, keep up the good work :)
RoninLB 01-05-2003 09:11 PM
Tony.. you deserve a bottle on this one.. I was worthless on helping you.. so will slow mail you a merry christmas.......Ron
ZAMIRZ 01-05-2003 10:42 PM
Tony, looks *****in man. Keep up the good work, I'll definitely be looking forward to the final masterpiece.
masraum 01-06-2003 12:36 AM
Fantastic work! Looks great, what excites me the most about it is the reduction in current draw. I feel I get enough light, but reduced current draw would be nice. a setup for the exterior lights would be cool.
Something like this, http://www.vintageled.com/LEDs.html
If you look at the raw photo's of the led arrays in this link you'll notice a couple of things, one is that there is a slew of resistors on the boards, and in one of them you see what looks like three adjustable somethings and a couple of chips. Any one of you electrical guys out there have an idea what/why this stuff is necessary? So you couldn't just stick a bunch of led's in a board and then wire them in parallel to the socket. I don't know miuch about leds, but I can imagine that since they don't draw much current you might need a resistor to simulate the bulbs presence to keep from blowing fuses, but at that point are you using the some amount of current??
Adam 01-06-2003 02:29 AM
Looks awesome, Tony.
I like the red, but the super-bright white is my preference!
vesnyder 01-06-2003 03:25 AM
Keep up the good work Tony. I will stay tuned!
Ray 911s 01-06-2003 05:32 AM
Both alternatives already look better than my stock situation! I'm really looking forward to the final results. Great work!
jabb 01-06-2003 05:59 AM
Both look good..... I like the Red
Tim Walsh 01-06-2003 06:18 AM
Both look really good, I personally like the white better if the dispersion would be a little better but both loook really good right now.
HawgRyder 01-06-2003 06:58 AM
Steve....the problem with LED's....they don't like too much current (amps).
So...they are rated at voltage and current.
For the sake of argument say one is rated at 2.5V and 30ma Max.....so you have to feed not more than 2.4V and limit the current to 25ma with a resistor.
Some cheapo units use a bunch of LEDs in series (6 or 7) and put them straight across the 12V line.
This is OK if the 12V does not go too high...but we all know the positive in these cars can sometimes get up to 14 to 15 Volts....so you over-power the LEDs.
With a good array...there are resistors....with an expensive array they use current limiting chips (integrated circuits).
There is is in a nutshell.
Bob
johnnyo200 01-06-2003 08:02 AM
Really NICE! I can't decide either. My car is red and my stereo lights up red, but the white is just so clean and bright.
Okay, what if you could choose what color you wanted by a small switch on the dash. Years ago a buddy of mine had a car stereo that allowed you to switch between green and red lighting to match your car's gauges. What type of bulbs/leds would allow you to do that?
APKhaos 01-06-2003 08:36 AM
Answers
Steve,
LED performance curves are current sensitive - the resistors effectively set the operating current for each LED for optimal output. The vintage tail light assemblies are nicely done. If you take a closer look, their circuit appears to include on-board voltage regulation, which goes to the point HawgRider made about keeping the supply voltage constant.
On a related point, dimming incendescent bulbs is easy - just drop the voltage via a variable resistance [the dimmer knob]. Dimming LEDS requires a switching approach - switching them off several hundred times a second to reduce the 'effective' brightness.
Johhnyo,
There are several ways to do this, but they have problems. There are some multi-chip LEDS that can be switched [eg green to red] but their output is really low. There is not enough space to fit a red and a white set of LEDs without severely hacking the instrument cases. Best bet is to have tow sets, and change 'em when the mood strikes.
targa911man 01-06-2003 09:03 AM
Tony--
Great work. I like the red. Sounds like you're really close. I've got a pre-embargo Cuban double corona for you to celebrate with when it's done.
pwd72s 01-06-2003 09:30 AM
Man, this looks like a LOT of work and research. Question: Why does the red light thing up more evenly? Something about wavelengths of light?
RickM 01-06-2003 09:48 AM
Tony,
Regarding the bulb bases, you may want to give Stoddard Imports a call. They seem to be able to get the smallest of parts easily. They may also provide a bulk discount. They extended one to me when I built Turbo mirror electrical conversion harnesses.
http://www.*************/
Good luck.
Rick
MIK911 01-06-2003 12:39 PM
I'm bummed. For some reason, the pics aren't coming through on my computer. All i see on the screen is an icon.
Anyone have suggestions on how to view these pics?
thanks
Mike
'86 coupe
RoninLB 01-06-2003 01:05 PM
thanks
Mike
'86 coupe
non-expert- try refresh.. on top toolbar on my windows.. it looks like a legal size paper w/2 curved arrows in it........Ron
cegerer 01-06-2003 02:10 PM
Tony, does the red look that much more uniform in real life, or does it just photograph better due to lower contrast between red-black and white-black? My wife has a Pontiac Montana with red instruments and I think they are horribly difficult to read. Maybe it's just my eyes are aging??? -- Curt
APKhaos 01-06-2003 02:19 PM
Curt,
I should have re-shot the red pics, because it is nice and uniform in real life. The human factors geeks preferred red for instrument lighting because it preserved night vision. The more recent humfac favorite is blue. I understand that the navy has spent bazillions changing its shipboard combat command centers from red to blue lighting. Sounds like a contractor's windfall, right?
I prefer the higher contrast of the white lighting, but others prefer the red [or even other colors found in sushi rolls].
Mike,
The pics are standard jpegs - hope you are seeing them now.
masraum 01-06-2003 03:41 PM
Mike, it's probably a combination of things, the fact that the names of the images have spaces in them and the browser you use. If you have another browser try it. That would probably be your best bet.
cegerer 01-06-2003 04:04 PM
<i>"The human factors geeks preferred red for instrument lighting "</i>
That's what I thought. I think BMW has promoted their red instruments for that reason. I guess I'm outside the 99th percentile .... ;) -- Curt
Ray 911s 01-06-2003 05:25 PM
I've driven Pontiacs with red, Fords with what seemed to be blue, and GM "sliderules" that could get as bright as the highbeams. For my 911, I really just want brighter than I have; if the cost of such an upgrade is reasonable, I'll do it regardless of color. That said, if there were a choice of color once it was done, I'd buy red(ish).
RAM 01-06-2003 05:59 PM
I do like the red but not sure how it would look in a Gulf Blue (Baby Blue) 911?
Great work
GSpreeman 01-06-2003 06:31 PM
Can you give us a brief write-up of how you're doing what you're doing? I want to get a better sense of how much stuff you're having to do do to get these results. BTW, I hate the OEM dash lighting...I'll be the first one on the block to drop in the LED's into the Pcar.
Keep up the good work!
BW911 01-06-2003 07:03 PM
Great work, Tony. Us local Pelicanheads will be lined up for install when you are ready to broaden your test. :D
Bill
'88 Carrera
APKhaos 01-06-2003 07:31 PM
Thanks Bill - the first production batch will be tested on willing NOVA Pelicans :eek:
Curt: the humfacs preferred night color changed to blue around 15 years ago. You were ahead of your time.
Ram: a color consultant can probably help you with that question ;)
Ray: Red[ish] is in the eye of the beholder.
GSpreeman: I plan to expose the whole gnarly process once the design is finalized. Some assembly is required.
83911sc 01-07-2003 05:06 AM
Tony -
do you need any more guinea pigs - I've got a spare clock which I can send your way if you are still in that phase. Oh yeah, I've also got a very willing 83sc just dying for a light lift ;) Even though I'm no in VA, I'd love to "help" you test this. :p
Adam
robs 01-07-2003 07:17 AM
Re: Instrument LIGHTS experiment - Part 2
[QUOTE]Originally posted by APKhaos
For those Netscape users who can't see the photos:
Phase 2 White Panel.jpg:
http://forums.pelicanparts.com/uploa...te%20Panel.jpg
Phase 2 Red Panel.jpg:
http://forums.pelicanparts.com/uploa...ed%20Panel.jpg
Phase 2 Red Tach.jpg:
http://forums.pelicanparts.com/uploa...Red%20Tach.jpg
I replaced the spaces in the file names by %20.
You can select "quote" to see the source code of this post.
Hope this helps.
Ray 911s 01-07-2003 07:26 AM
Organ donor
I also have a clock I can donate for the good of the project if you still need addiional test subjects.
Joeaksa 11-29-2003 06:15 AM
Tony,
Have sent you a couple of emails asking if how things are going with the LED lights and as well asking if you received the 911 Tach I sent you a long time ago. No answer to either email so not sure if your email address has changed or what.
Pls advise when you have time.
Thanks,
JoeA
exc911ence 11-29-2003 08:37 AM
I'd like a blue hue like the current VW models have... it would match the blue lighting on my Blaupunkt! :)
Randy Webb 11-29-2003 12:59 PM
How about some light weight LED tail lights?
Don Z. 11-29-2003 07:26 PM
Way cool... is Annapolis MD close enough to NoVA?...
How about a blue test as well? Just curious... This is awesome... what can we do to help?
Z
stlrj 11-30-2003 08:44 AM
Too bad there wasn't a way to get that bright blue backlit effect like a Jetta.
Joe
Early_S_Man 12-01-2003 12:08 PM
Well, blue is OK, appearance-wise, but for older eyes Yellow-Green is best, because that is the wavelength at which human eye spectral response peaks! Anyone remember the Yellow-Green 'ES' series of Pickett slide rules in the '50s and '60s? That particular shade was chosen to mimimize eye strain.
Another option most here have overlooked or forgotten ... as I have mentioned it before -- is to build your own higher-power incandescent bulbs by unsoldering the old envelope from their bases, and soldering & glueing a higher power bulb to the brass base. Eiko DE3022 are 5 Watt bulbs only 9 mm O.D. ... and 3021 are 3 Watt bulbs identical in size. Many local auto parts store stock them for around $2 a pair.
http://www.eiko-ltd.com/eiko/item.asp?qid=37&lid=DE3022
Now that the first week of the holiday season is over, I may get a chance to build up a couple of sets of two bulbs based on the 3022 and 3021 bulbs, which may work well in the smaller-size combination instruments. When I test them in some spare instruments ... I will post pics of the assembled bulbs and resulting illumination patterns in tach, speedo, and combination instruments. I will take Gossen light meter readings via a fiber-optic probe ... comparing the gauges with new Wagner 11009 2 Watt bulbs and the 5 Watt and 3 Watt modified bulbs.
APKhaos 12-01-2003 01:57 PM
The project has been stalled while seaching the world [literally!] for a source of the bulb bases in quantity. Through the prototype phase I've been de-glassing the stock bulb bases, which won't work for quantity builds. The only source I have found wants a minimum order of 40,000 bases! I'd be fine with an order of 4,000 bases, but 40,000 is a bit high.
Until I can find a source that will sell in the 1000 unit range, its a problem.
Joe, Dave B, and others have provided a great range of older gauges that have been fantastic for testing and perfecting the lights. I have all the gauges, and will get them back to their owners when this project gets finalized.
The prototypes have been in my car for almost a year now, and are performing beautifully. The standard LED types just don't work, but the Luxor emitters work beautifully. I am ready to produce them IF there is a solution to the base problem.
RickM 12-01-2003 02:13 PM
Tony,
PM me with spec on the bulb bases. I'm pretty good at sourcing stuff like this.
jase007 12-01-2003 02:29 PM
Tony:
Personally I like the white versus the red. Which color will you go with in your future track car? ;)
Great job, can't wait to see the final results.
Jason
steve911 12-01-2003 02:41 PM
Tony-
add me to the list of interested parties once you've solved the bases issue.
