Need to be 3sec faster 84 3.2
Hi,
I don't post much, but I figured I'd reach out to you guys. I have a euro spec 84 911 I've been autocrossing. I am looking for winter projects and figuring out where to put my money. I currently just beat my 3.2 counterparts (somehow) and want to try to beat my friend and I need to deduct 3 seconds from my time (out of 75ish seconds). I currently have some weight reduction (no back seats, no AC or blower). I have quickchange torsion bars, fairly light Corbeau seats and a harness bar/harnesses. The car also has a cheap cone filter intake, an unknown 4.5" single outlet exhaust, and 17x8, 17x9 twists wrapped in some old 225/45/17, 255/40/17 Potenza RE050's My friends car is a 964 AWD Cabriolet with KW coils and some exhaust work with Potenza RE-71R's My plan is to get myself RE-71R's of my same size, do some routine maintenance and splurge on some mods. I was thinking a Steve Wong chip, maybe a Tarrett front sway bar and maybe a throttle body enlargement? Any further weight reduction I can do? Oh, I also want to corner balance. I know there are a bunch of "get fast quick" threads (which I've read)....but really just looking to chit chat. Is three seconds possible? https://c6.staticflickr.com/6/5715/2...7b710e6c_b.jpg |
In order:
SW Chip Brakes ( you did not mention brakes, believe it or not Good Brakes help reduce lap times ) Corner Balance Sway bar would be good if #2 & 3 are taken care of first ( Actually #3 at the same time ) |
The first thing I'd do is buy a set of 15" Fuchs and put autocross tires on them. The wheel tire combo you have is slowing you down a bunch.
Talk to someone like Chuck at Elephant racing and give him a list of exactly what suspension components are on your car. My guess is that you have a bunch of parts that aren't optimum for each other. Make the changes he suggest and do a corner balance/alignment with settings suitable for autocrossing. JR |
Pro coaching. Fix the loose spacer behind the steering wheel first, then address car with a pro suspension and alignment evaluation and setup. Depending on the track, 3 seconds is possible. Chip and sways might be good for a few 10ths. Light weight 15" wheels and tires will make a significant difference in performance depending on your AX course. If you use 2nd gear only and are near redline in the fastest sections, smaller won't help much because you will be shifting into 3rd with smaller wheels.
I second the idea of getting a set of 7"/8" light weight 15" wheels. I saw a set of real fuchs in good condition with a crap paint job for $1100 in the for sale just last week. You will see the most bang for buck here in my opinion.
in order
improve the nut behind the wheel 15 inch wheels and tires- Buckley racing wheels 275 rear 245 front with hoosiers will give you much better grip, better braking and much more torque / better gear ratios. 2 hawk blue brake pads or similar. if you are running a oem pad you are leaving extra time on that track 3 more weight reduction, front and rear bumpers should shave off over 50 lbs Easley. light weight battery, remove spare tire..ect..ect. 4 aero- but this can get very complicated and expensive. 5 more suspension work. |
I'm pretty set on the current wheels (at least the sizes)
Bumping up to Hoosiers would put me in a different class (and make me switch wheels at the track), and RE71R's are only attractive at 17" diameters. I'm really optimizing my grip I think with the 17's as I'm maxing the contact patch and available sizes offered from Bridgestone. Are there any decent tires available for 15's other than Hoosiers? Something with greater than 140 treadwear? In order to downsize wheels I'd have to go with 205's.....which seem far too puny to me.....even for my VW Scirocco I'm race prepping. (which is getting 15's though) My brakes are factory and as you can tell from the picture they grab pretty well ;) but I was thinking about new rotors and some good pads. My buddy who does DE says the original brakes are sufficient even for him. Hawks sound good though....probably super beneficial Has anyone gutted the bumpers? Mine are Euros so I imagine not filled with that American safety garbage. A lightweight battery sounds like a good idea....any concern with taking even more weight out of the front? FYI, this is my second year autocrossing and I am in the mix of (and just beat) some verrrry experienced people with the same car. I'm not a spring chicken. |
I've got Toyo's on my 7/8" combo. They are all less expensive in 15" size. Proxes RA1.
I would put corner balance at the top. Stock brakes are fine for autox, you only use them about 5 times, some of the others mentioned don't work until they get hot. Then weight reduction, cheaper than adding power. M&K muffler on my car is 10 lbs vs stock at 30 lbs. Tires, I've run Yoko Advan 205X50X15 for years both autox and mostly DE's but I couldn't believe how good they where at my first autox, they are about 140 tread wear. Then the rest is up to you, learn to be smooth, think what the tires/suspension are trying to do, transitions, turns, brakes and acceleration, smooth. Walk the course, look for anything that can upset the suspension, where to brake, trail brake and any straight section where you can get on the power. Good Luck
The bumpers are essentially the same worldwide. The only differences were in the bumper mounts and the bumper trim (especially on the rear) so there's lots of weight to be saved if you install fiberglass bumpers on both ends. Saving weight anywhere you can is a good idea. I don't know what changes you've made thus far, so I can't tell you where to go next. Don't forget the suspension. I suspect it's far from optimum for autocrossing, so talk to an expert and change what he tells you to change. 2 years may seem like a lot of experience but in the autocross world, that makes you a newbie. Add up all the seat time you've done; you'll find it's not all that much. Because the runs are so short and you don't get all that many in a day, it takes years to get much experience. There are a few good books out there on the subject; they are worth a read. JR |
Seat time.
And your up against AWD. Good luck making up 3 seconds on a 75 second course. |
Really?
Average ford F150 pickup has 2.7 Ecoboost V6 with 325 horsepower @375 torque. 3.5 Ecoboost V6 has 375 horsepower at 470 torque. Not even going to mention the V8. So why remove your back seats and AC? I've driven these powerful cars, on a straightaway, you will never see them again.
His tires and rims are 25 inches OD, same as the fuchs sizes you recommend. WHat do his rims weigh compared to what the Fuchs weigh? Are the Fuchs you recommend wider?
Your car is already faster than your friends 964 C4 Cabriolet, that is at least 400 punds heavier than the '84 Carrera. With the Euro spec engine, the additional 16Hp in the 964 is not enough to cope with the additional weight and the (big) negative impact of the front wheel drive.
Like others have said, it's seat time, seat time and seat time. And then 15" wheels with lower profile tires (23" OD), those will give you an 8% lower gear ratio compared to the normal (25" OD) wheel/tire combination. Try the Hankook R-S3 tires, they are great for AX! |
Fuch 7 x 15 = 13.5 lbs
Fuch 8 x 15 = 14 lbs I just picked up a set to refinish over winter. Look forward to putting some Perelli's on them and feeling the benefits I have been reading about. |
My recommendations is for 7x15 & 8x15 Fuchs, so they would be narrower than what he has now. The tires for the 15's would range in diameter from 22.5-23" for the fronts and 23.5-24" for the rears, again depending on his choice. So. they are significantly smaller than what he's running now. JR |
a good friend that was a top autoXr was telling me that was his key. I was asking him about later and harder braking and he said he does not do that, the key is getting on the gas as early as possible, also your line,. don't drive to the inner cone and look ahead. big + on the 15's. I can see my 930 being slower with 18's than my brothers with 16's. just straight line accel, |
I dunno what the hollow twist rims weigh. I am fairly certain you're right, though.
I'm all about seat time, and can guarantee I'll be maxing out next year. Still not sure about the wheels though. I'm a big fan of empirical data so I'm going to pursue that. I have some RS-3's NT01's and RT615K's for my Scirocco but I've heard they don't hold a candle to the RE-71R's (well....the NT01's do but are technically R Compound) |
Also, I'm bouncing off redline in 2nd gear at points which is about par for the course. I'd have a hard time conceiving wanting to be geared even lower. The autocross track we have is an airport that tends to be a quick mile+. |
Miata battery or the AGM 25lbs battery will work. After all the weight removal do the corner balancing. I have to redo mine because of lighter starter and muffler. |
The updated starter is lighter? Which one is this?? For my Scirocco I got a Featherweight lithium ion battery. Thing is suuuuuuper light. Very expensive though to get more CCA. |
What torsion bars are in your car now? |
Sway bars are stock for the moment. Raise the spindles? You mean cut and Fab them? Sounds dicey. I also installed Weltmeister steering rack spacers. Cheap and does the trick. For weight reduction, have you guys seen this?? Wps Featherweight Lithium Battery 500 Cca Hjtx30L-Fp-Il Hjtx30L-Fp-Il I bought a 200 CCA one for my Scirocco which does the trick.....but with these batteries you're talking ounces....not pounds. |
Those big fat tires hurt you in three other ways. One, they're probably 50 pounds heavier, as a set, than what I suggest you run. Two, they will have a much higher rotational moment of inertia, which kills your acceleration. Three, they are taller, so you effectively have taller gearing. Quote:
You need to fix the problems your car now has, and it is far from optimum for autocrossing-trust me on this, and you need more seat time. Have fun, JR |
In my very limited experience (though I've done lots of watching, listening, and asking), tires alone can be worth 3 seconds on a course that long! And if you've never experimented with lighter vs heavier wheels + tires, it's crazy how noticeable that difference is. Shorter diameter is even better for acceleration, though in certain situations that could just set you up to lose time on an extra shift.
Either way, the 964 driver clearly knows how to throw that floppy 'vert around the cones. I absolutely agree that a 3.2 coupe should be quicker given the same driver (and equal tires). One common thing all of the quickest autocross 911s seem to have are custom-valved shocks. I'm not sure anything off-the-shelf aside from coilovers (which probably class you out of competition) is ideally valved for autocross. |
Your old RE050s are clearly at least 3-5 sec off new RE71Rs. That's the first thing you should change. 225 and 255s on the 17s should be good. Set your alignment to at least -2.0 camber f, 2.5 rear, with 0 toe front, proper corner balance and you should fly.
A good rule of thumb is that each 100-110 lb weight reduction is good for a 1.0 sec reduction on a 1:30 track lap, or 75 sec AX course. You can see that on AX lap times when a passenger rides along. The subject of weight reduction is a long one. The first 150 lbs are the cheap and easy ones. Regarding HP, a good rule of thumb is each additional 10 HP is good for a 1.0 sec lap time reduction on a 1:30 lap. So a 15 HP mod is good for a 1.5 sec reduction. Make sure you are getting full throttle at the throttle body and that the full throttle microswitch is working and activating. I used to run 22mm sway bars front and rear on my 3.2, but on the advice of Rich Walton of JWE, changed to Smart Racing 31f/27r and the car was instantly 1-2 seconds faster. You could literally dive head on at a cone, heel toe into first, and throttle steer the rear end 180 degrees around it and power out. Brakes do get hot in AX. Good ventilation, a set of Raybestos ST-43 pads, and Endless RF650 brake fluid are a good start. |
The 964 driver is very very good. He does know how to "throw that floppy 'vert" :) I have dampening adjust on the front but non-adjustable rears. Probably on my to do list. Coilovers would throw me into another class I'm pretty sure...yeah. |
I feel I don't have the rear grip right now to throttle out like you said hehehe, maybe with the new RE71R's. Also, thanks for the Camber specs!! I am probably running too much front camber and not enough rear at the moment. Eager to get that alignment and corner balance. |
your car looks like it is doing pretty well I the pic, no excessive body roll.
if you can get the 225/255 in a 15 with the same profile spend the money on the rims. that is like adding HP, it lowers the CG by 2 inches which is a lot which is also a BIG improvement without changing the suspension geometry. your looking for 3 sec out of 75sec on a low speed course, that's a lot of time. you need the acceleration. trying to increase your cornering speed takes a lot of $$$ + you have to be able to utilize it in your driving skills. getting from one turn to the next is easier to improve. say you have a 30 turn course. that's .1 sec per turn or .1 for accel for 3sec improvement. keeping one or the other the same, which would be easier to improve. |
Oversteer can occur on the entry into a corner, through the corner and exiting the corner. Don't confuse the basic balance of the car with oversteer that arises from driver inputs. Quote:
In my area, the fast guy is fast in his car, or in any other car he sets his butt in. He'll beat anybody's best time, in their own car, the first time he runs it. It doesn't matter if it's a 100hp 914-4, or a 600hp uber-Porsche. He's that good. Modifying these cars isn't cheap. I'd rather have one car that was set up well than two that were set up poorly, so maybe my priorities aren't in line with yours. I will say that any advice I get from people that have spent a lot of time learning it usually get my business. I'm working on a car now that I've talked to Chuck about. When I get to the point of buying parts, he'll get my business as a reward. Good luck to you, JR |
By the way, in several of the photos you've posted of your car, I see a lot of tire smoke. Your corner balance is probably a mile off and your tires may be long past their useful life. Swapping tires and re-aligning the car will help a bunch, but I'd do all the other work first, so you don't have to corner balance the thing more than once.
JR |
I have an 86 Carerra that I've autocrossed for years.
-Fully agree with everyone suggesting 15s. I run 225/45Hoosiers on Fuchs 7/8X15s Running a square tire setup lets me move the tires around as needed to equalize the uneven wear. There is still a bit of tire footprint difference (maybe 1/2 inch) front to rear because of the different width wheels. -Get the car as low and stiff as possible. Adjustable sway bars enable fine-tuning the front/rear balance to suit your handling taste. -I run SSIs and a SW chip. The car pulls very quickly from 2-5000rpm in 2nd gear, where you will be most of the time. -Aggressive weight reduction with FG bumpers would be the next step for me. |
You need adjustable sway bars to get the most out of the car. It has way too much understeer now. Yes, cutting and welding is required to raise the spindles. Not dicey at all. It is done all the time. |
I did some math and I think my setup is 17lbs heavier. I think ideally I'd find lighter 17" wheels. Our courses are a lot of corners and slaloms. I also feel like 205's would look stupid on the rear of my 911. Maybe it's a negligible concern and I'm being prideful, but I like having big meaty tires in the rear. https://c8.staticflickr.com/9/8274/2...4d10d310_b.jpg https://c6.staticflickr.com/9/8135/3...ced887bf_b.jpg |
