I have a 76 911S Targa. I've read some threads, saying that they removed the smog pump, from these kind of engines. I don't think it takes much horsepower from the engine, if any, and I would think that it would cool the exhaust gases, keeping the engine slightly cooler. Since the exhaust goes right pass the engine.
So why disconnect the smog pump? |
Buy them, sell them
Welcome to the board!
As I understand, it's quite heavy. Seeing that you don't live in CA, it's also a superfluous piece of engine bay equipment that restricts access to the left side cylinder bank. I'd remove it (mine's gone), but keep it in a box for the next owner.
1931 Oakland Eight Special Saloon 1985 BMW E28 525e (Euro 528e) 1989 911 Carrera Sport 3.2 G50 Cabriolet |
adding air to the exhaust just as it exits past the exhaust valve actually makes the exhaust hotter, the object of which is to help burn any unburned fuel that otherwise would be discharged into the atmosphere. cars with air pumps run just the same as those with it removed. they do get in the way of valve adjusts and sparkplugs, and the engine does look better with it gone. emission standards for the engines that had the pumps are fairly loose, so most can be adjusted to pass smog without it, unless there's a visual test required.
Montana 911
I have a pump for sale if anyone is interested...like new!
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
Buy them, sell them
K9,
I've got some old warped Magnesium valve covers and a crummy 5-blade fan for sale too...
If you remove it (which I recommend if you don't need for smog), make sure to plug diverter valve. Other wise it will run like crap(ask me how I know). Of course, that's if you don't remove the whole assembly.
Montana 911
Cool Adam,
I can trade you a slightly used tie-rod end, a half used set of squeaky brake pads, and a broken clock! ha ha
GAFB
How about the rusty metal boogers I just sliced out of the nose of my new '72? Original, vintage, Porsche sheetmetal; with that "patina" of age.
Several BMWs |
Buy them, sell them
Hmm. I'm also looking to "unload" my old school-bus sized original steering wheel... I'll swap you for the rusty boogers!
Win, In the '80s,I had a 2.7 totally rebuilt here in CA at Andial. At first, I ran the pump with the belt off. Then I put the belt on for smog. Then, sometime later, I took the belt off. Pretty soon the pump was almost frozen. I kept asking Arnold at Andial what I am doing to the motor putting it on again, off again. He said no big deal but he also said that he was supposed to tell me to leave it on because of being licensed as an auto repair facility in CA. As far as I could tell, he didn't care if it was hooked up or not and I couldn't tell any difference either. I know this contradicts what JW said, but that is the way it was. In the end, I ran the belt. Owned the car for 15 years.
GAFB
Several BMWs |
I removed the smog pump when I upgraded to Carrera tensioners...and my car runs much better. I keep it handy for my once-a-year inspection.
- Dr. Scott ______________ '77 911S Targa |
