-   -   New wheels - alignment needed? (http://forums.pelicanparts.com/porsche-911-technical-forum/933187-new-wheels-alignment-needed.html)
Christien 10-22-2016 12:50 PM
I just replaced 6 and 7x16 wheels with 7 and 9x16s (both sets are fuchs) and now my steering wheel seems to be slightly to the right. Could changing wheels of the same size necessitate an alignment?
brianlay 10-22-2016 04:46 PM
Wheels alone would not change the alignment.
New tires as well?
Maybe increased grip has magnified a problem that was already there.
manbridge 74 10-22-2016 08:47 PM
Well if ride height changes so does toe in/out. A small amount that may or may not justify an alignment. Steering wheel shouldn't have changed position though.
Christien 10-23-2016 08:33 PM
The old tires were a 50 profile, and the new ones are 55. Does that make a difference?
javadog 10-24-2016 06:43 AM
No.
Driven97 10-24-2016 06:50 AM
Not if that ride height change came from a tire diameter change. Suspension arms are still in the same positions they were before.
McLaren-TAG 10-24-2016 08:30 AM
Maybe the tire installation shop took it for one hell of a joy ride? Or maybe they jacked it up all wonky and bent a suspension A arm or a steering rod. Or maybe you're just going cray cray?
Keep us updated as to who the real killer is but as others have said, it's not due to the wheels and tires unless your previous set was WAAAAY unevenly worn, but you'd have notice that; right?
Christien 10-24-2016 01:05 PM
I would think I'd have noticed that, but the car is relatively new to me so it's possible I just didn't notice it before changing the wheels, and I was hyper sensitive to it after the change. I did the wheel change so I can say with certainty nothing was damaged. As for any hooligan driving, well.... ;)
brianlay 10-24-2016 01:30 PM
if you still have the old front wheels and tires, put'em back on and compare!
matthewb0051 10-24-2016 01:54 PM
Switch the tires side to side, unless the tires are directional. I had similar situation on an Audi once and that solved the issue.
vascott01 10-24-2016 02:37 PM
No
Just throwing this out there..are the tires the same size, make and model on each side for both fronts and backs. People do make mistakes when replacing
zedsn 10-24-2016 03:37 PM
Just a thought but maybe your old tire may have been worn down on the inside or outside some and the new tire changed the footprint so to speak.
manbridge 74 10-24-2016 06:19 PM
Well doing alignments on regular basis I find wheel swaps of different sizes can exhibit different values.
In in any case, the OP needs to visit the alignment rack.
