Mothy's Avatar
Send a message via AIM to Mothy
993 v 911SC shell shape
I am looking at putting a roll cage into my 911SC - used for club level motorsport sprints.
A cage from a 993 turbo is available which suits my requirements
BUT
I am unsure if the interior cabin dimensions and mounting locations changed much with the 993 over the earlier 911 G series shells. Things like the shape of the rear parcel shelf below the rear window for instance.
Has anyone done a similar fitment of a cage from a 993 to an earlier 911?
Swapped my WRX Sti MY02 for a Porsche 911SC '83
Keep buying parts to make it look older.
Mid life crisis is now in its 12th year.
Old 07-31-2017, 08:56 PM
puddy's Avatar
I was looking at a great deal on a 993 cage for my 75 911 chassis, but then I was told it wont fit, not without modifications. So how much time and effort are you willing to invest?
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 08-01-2017, 05:12 AM
gearhead
Keep shopping. Way too different.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 08-01-2017, 05:29 AM
3rd_gear_Ted's Avatar
When you weld the roll cage mount pads to the interior sills, just add some welded vertical tubing of proper diameter to slide the existing ends of the roll cage into. Put cage into car and jack up cage to proper height and weld in place. If a sunroof delete was done, getting the cage to the right height needs to be done.
This way cage welds don't need to be done through holes in the roof corners
1980 911 - Metzger 3.6L
2016 Cayman S
Old 08-01-2017, 10:26 AM
Check with Customs cages and Safety devices as both have FIA spec cages. I'm currently in the market for one myself.
Old 08-01-2017, 10:37 AM
