Tori's Avatar
14 pin connector help
I cannot for the life of me get the male side (car side) of the 14 pin connector snapped into its holder in the fuse holder bracket. Is there a trick to this ? Seems pretty straight forward, but i've tried every which way.... straight in, bottom in first, top in first... nothing. I've pressed as hard as i can, and next step i'm sure will break it.
Is this common ? I'm going to try heat in hopes of softening the holder some....
Also, anyone have a wiring diagram for at '87 for this connector ? The search only netted me diagrams for 70's cars.
Thanks guys.....
1987 911 Carrera Coupe
1987 Buick Grand National
1971 Plymouth Roadrunner
Old 12-18-2018, 06:13 PM
Are all the pins straight?
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-18-2018, 06:19 PM
Tori's Avatar
It's not pin to pin connection i'm trying to make. It's the harness into the holder. The body of the connector needs to snap into a holder.
Old 12-18-2018, 06:30 PM
disband
juanbenae's Avatar
the wires have to be routed, set down all tidy like in the harness case in a specific order to get it all to fit and snap shut.
Old 12-18-2018, 07:26 PM
Tori's Avatar
While i get what your saying,... what a joke these connectors are. All the pins are loose and slide easily back and forth. That wasn't the problem however. It was the rock hard, 32 year old plastic of the holder.
The heat gun made it flexible and that allowed the connector to click in place.
Old 12-18-2018, 07:38 PM
l_turn9's Avatar
Glad to hear you got it together,
If you're still looking for a wiring diagram, I just downloaded one from a different thread. It's for a 88 Turbo but I downloaded it to use on my 74 911 - it's looks pretty close except for a few details, you're should be even closer.
Try this link - there are several diagrams of the 14 pin connector - one for a 78 Turbo and one for a 88 Turbo, maybe more.
https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/601232-engine-wiring-harness.html
Good luck
Old 08-13-2019, 03:05 PM
Tori's Avatar
If you're still looking for a wiring diagram, I just downloaded one from a different thread......
Good luck
Thanks for providing this. My car is working properly now, so i'm all good.
Cheers !
Old 08-13-2019, 07:42 PM
